Notch In Girder - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 02:02 PM   #16
MJ Force's Avatar
Rewards Points: 150
Once everything attached to the girder is supported properly you could lower/remove the post. The girder may still be attach from the flooring nails/screws above. You may need some elbow grease to pop it off. Any screws protruding through the subfloor should be ground off of course. If your you use a grinder to cut the nails make sure you wet the area lightly with water to extinguish sparks before and after.
MJ Force is offline   Reply With Quote
Old 04-18-2013, 03:25 PM   #17
Rewards Points: 626
That is bad! I hope every one read your post. Never ever notch a girder. unless you have a engineer sign off on it. It might behove you to talk with a engineer and have them run the calc on it and see if it OK to do so and save you the headache of removing and putting back in that girder.
Nailbags is offline   Reply With Quote
Tags
framing , girder , notch
Hanging and finishing girder truss/joist hanger transition crankcase Drywall & Plaster 1 10-27-2012 12:34 PM
rotted girder on posts balloon frame azs Building & Construction 8 10-24-2012 09:41 PM
Girder Steel or Wood Jameson1 Building & Construction 11 03-12-2010 06:38 PM
Girder Direction JeroldLopez Building & Construction 1 08-28-2009 08:38 PM
Supporting girder with wall Geber Carpentry 3 01-29-2007 10:53 AM
