Not Sure If This Is The Right Place, But... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 05:46 PM   #1
Question
here goes anyway.
I have a wood burning zero clearance fireplace that was installed about 25 years ago. The contractor put in a chimney with a triple wall 14" outer pipe. My problem is that the chimney cap was damaged in a wind storm and I'm looking to replace it.
Does anyone have any idea what size cap I should be looking for? I've seen 6" and 8" caps and assume that's the diameter of the inner pipe. If the outer pipe is 14", I would guess I need one that fits the inner pipe at 8". Am I correct?
The chimney itself is in good condition - it's segmented galvanized and tight (doesn't leak when the fireplace is in use.
Any ideas here?
Thanks!
Hacker15 is offline   Reply With Quote
Old 03-08-2008, 09:55 PM   #2
Rewards Points: 5,336
Why can't you just go up on a ladder and measure the pipe you have? Or just take the damaged cap to the store and get one exactly like it.
Ron
Old 03-09-2008, 03:23 PM   #3
Hi, Ron. The cap is still attached to the pipe and (being upstate New York) there's about a foot of snow on the roof (both garage and upper roof) so I'll have to wait 'till spring to do anything. But thanks for the come back on this - I was just curious if there was any type of standard for these chimney pipes (14" outter pipe means an 8" inner pipe, etc.)
Old 03-09-2008, 04:16 PM   #4
I was up in Copake, NY(about 120 miles north of NYC) a few weeks ago and it was snowless. Big surprise for me. I expected alot more.
Ron
Old 03-09-2008, 04:25 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Do you have the original manual & information for your stove?
Can you look it up? Generally, the stove manufacturer dictates the design of the smoke stack, the details may be there.
Otherwise, you will have to wait till any snow subsides, and go measure it.
Then, go to a stove/fireplace shop, and look into getting a new cover from them.
I have spent alot of time dealing with people's roofs this winter. It amazes me, how I can get into some neighborhoods, with homes that have roofs still covered with snow, because of their location. Then, I can drive to the other side of town, and see no roof snow at all, on other houses.
- Build Well -
Recommendations for place to buy faucet and sink kptbls Remodeling 7 03-02-2008 02:14 PM
J-channel on drywall edge, do I glue or just put in place yummy mummy Building & Construction 14 01-29-2008 04:10 PM
Good place to buy decent fixtures? twilightcall Plumbing 3 01-23-2008 07:23 PM
Cheapest place for replacement door hinges (interior) Proulx06 Carpentry 6 09-29-2007 04:17 AM
Patching drywall-where to place seam? AllGoNoShow Building & Construction 6 09-20-2006 11:02 AM
