Old 01-02-2013, 01:55 AM   #1
Not really DIY but had to post
what do you guys think of this? is this DIY possible? i am referring to the slide, not the pool. seeing this pic made me think about having this coming out my window, with a landing pad on the ground. i am crazy........right
federer is offline   Reply With Quote
Old 01-02-2013, 02:24 AM   #2
Super Moderator
Is that going to be the exit for door to door salesmen and other unwanted visitors?
Your neighbors will love it---I say ,"Go for it!"
Old 01-02-2013, 02:46 AM   #3
you'll need slick clothing (going naked won't work, unless you are real sweaty) or water running down it.
The Following User Says Thank You to jklingel For This Useful Post:
federer (01-02-2013)
Old 01-02-2013, 03:55 AM   #4
hahahhaha i didint think of that
Old 01-02-2013, 09:35 AM   #5
You would need to design it for a landing pad, you would hit to hard with this style. The fireman pole would be easier to install. I would make a model from pvc first then send hamsters down so you can find the set up that works best. Probably want to make little outfits for the hamsters first so you will get a more accurate idea how how the slide will function.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
federer (01-03-2013)
Old 01-02-2013, 10:54 AM   #6
STAFF
BigJim's Avatar
Man are you in trouble now, PETA is going to eat your lunch.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 01-02-2013, 06:27 PM   #7
And the SPCA is right behind them.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 01-02-2013, 06:41 PM   #8
Wire Chewer
Red Squirrel's Avatar
I think it would be awesome to do, but make it so it goes just slightly over your car, and see if you can program your remove to open the driver window. That way you can land right in your car. Shovelling is overrated. Just get in and drive!
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 01-02-2013, 07:13 PM   #9
if by crazy, you mean awesome. Yes you are.
Only problem I could foresee would be if you have bears in your neighborhood. Cuz at some point, one is going to decide to take a nap in there and it could get weird when you slide into him.
wrongdave is offline   Reply With Quote
The Following 2 Users Say Thank You to wrongdave For This Useful Post:
bigchaz (01-03-2013), federer (01-03-2013)
Old 01-02-2013, 07:39 PM   #10
JOATMON
ddawg16's Avatar
If your crazy......then your not alone.......
I did this for my kids.....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 01-02-2013, 11:51 PM   #11
Exterior Construction
Windows on Wash's Avatar
Do it!!!
Old 01-03-2013, 01:04 AM   #12
hahahaha i love you guys! what a group we got in here.
you guys think of everything. i might seriously consider this.
edit: too many problems going on right, but i will come back to this thread.
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 10:56 AM
Tiling vertical post kellyharris15 Flooring 12 02-22-2011 04:28 PM
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 10:01 AM
