Not Able To Jack Up Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 04:59 PM   #1
not able to jack up garage
how can i replace rotted sill plate in freestanding garage that cannot be jacked up?
borgie81 is offline   Reply With Quote
Old 07-25-2012, 05:47 PM   #2
The only force on a sill plate is a downward compressive force, with no tensile force trying to stretch the plate along its axis.
Assuming the plate runs north/south, remove rotted areas and, in an east/west direction, force wide pieces, wide in the n/s direction, of rot-resistant material with the compressive strength of wood into the spaces you are creating. Anchor these pieces to whatever you can, with fasteners or adhesive.
Old 07-25-2012, 05:49 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
how is it built, that it can't be jacked up?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
The Following User Says Thank You to coupe For This Useful Post:
oh'mike (07-25-2012)
Old 07-25-2012, 05:51 PM   #4
kwikfishron's Avatar
Rewards Points: 176
More times than not you don't actually have to "jack up" anything.
Posting some pictures here would be a good start for some real advice for your particular situation.
How to attach a photo to a post
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (07-25-2012)
Old 07-25-2012, 05:56 PM   #5
Rewards Points: 2,210
Quite often the bottom of some studs can be rotten also.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
GBrackins (07-25-2012)
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
Garage floor Tomperro Building & Construction 3 07-18-2011 12:37 AM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 02:46 AM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
