Northern Ontario Cottage Insulation Help Pls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 08:39 AM   #1
Northern ontario cottage insulation help pls
We have just had our cottage raised and walk out basement constructed we are doing a lot of the work ourselves I have seen so many conflicting views on insulation... What is the definitive answer to insulating the exterior walls? Need a step by step structure is concrete block about 4 or so feet high then 2 by 6 framing This structure will have minimal heat during winter months (about 45*f) to prevent any heaving but not used much during winter . Thanks for any help!
Sellwithnic is offline   Reply With Quote
Old 01-03-2011, 10:17 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... Without a Fully insulated envolope it'll cost a fortune to maintain 45 in the winter...
Bondo is online now   Reply With Quote
Old 01-03-2011, 11:18 AM   #3
Will be fully insulated the upstairs is completely finished and insulated the concrete floor is being poured tomorrow furnace installing on fri so what to get insulated asap
Old 01-03-2011, 03:12 PM   #4
joed's Avatar
Rewards Points: 12,922
Are you putting insulation under the floor?
Old 01-03-2011, 06:33 PM   #5
Umm not sure I guess we can look at it as now a two story building, basement being brand new wouldn't normally insulate between levels. After reading some archives it Is recommended that plumbing and electrical be done first we cant do that with this lower level until spring (new service being put in and hydro co won't do Till then) what would you do to provide at least some insulation to get thru till April ? Main objective is to keep interior above freezing till then Thanks! Nic
Old 01-03-2011, 07:30 PM   #6
Registered User
Rewards Points: 5,516
Maybe joed meant under the slab rigid insulation board.... This will give an idea; http://www.energycodes.gov/support/slab_faq.stm
Use the search box at top of this page for basement insulation. If using f.g., get the HD; http://www.diychatroom.com/f98/how-b...ulation-90438/
Gary
Old 01-03-2011, 07:51 PM   #7
Thanks Gary. Ideally we were going to have the entire area spray foamed but can't do that till spring either if you knew you still had to do your plumbing And electrical what would you do as a stop gap to get thru one season..or we could just go thru buckets of propane for the yet to be installed furnace Nicole
Old 01-03-2011, 08:19 PM   #8
Bondo's Avatar
Ayuh,... You can't spray foam Under the slab...
It's a thermal break that if Not installed, will cost you Forever...
Old 01-03-2011, 08:19 PM   #9
joed's Avatar
I meant under the slab not between floors.
Old 01-03-2011, 08:20 PM   #10
joed's Avatar
No plumbing = no heat required to me. My cottage gets all the plumbing drained every season and no heat through the winter. Why do you feel the need for heat?
Old 01-03-2011, 08:49 PM   #11
Was told by concrete contractor to keep above freezing this year Hmmmm
Old 01-04-2011, 07:45 AM   #12
joed's Avatar
Except for 4-5 days after the pour I have not heard that before, but if that's what he wants what can I say. I'm not a concrete contractor or expert.
Also if you insulate the inside the concrete will be on the cold side so what's the purpose?
Old 01-04-2011, 11:14 AM   #13
Good point joed. Owning a second property sometimes Is not worth the effort
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
cottage insulation Cottagers Building & Construction 1 05-02-2010 01:48 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
