Old 01-02-2007, 05:58 PM   #1
They're all fixer-uppers
J187's Avatar
Is this normal for an outside wall?
In the basement of my split level home, I just discovered that the interior side of an outside wall is nothing more than insulation and some wall paneling. Is this common? The downstairs always had issues with being too cold. Originally I thought this was due to the garage, but now I believe a significant portion of the draft is coming from this whole wall. I intend to take down the panelling and install drywall, but I'm just wondering if this was a common practice and why?
J187 is offline   Reply With Quote
Old 01-02-2007, 06:18 PM   #2
What material is on the exterior of this wall?
redline is offline   Reply With Quote
Old 01-03-2007, 08:58 AM   #3
J187's Avatar
Plywood sheathing and masonite siding.
Old 01-03-2007, 10:13 AM   #4
I think the original home owner choose panel rather than drywall and that is legitmate to save works... the insulation still be the key and you mentioned you have it.. so in theory, that shouldn't be a big different.. although I will agree drywall would be still a bit better than panel in terms of insulation... but you shouldn't feel big difference. do you have vapour barrier...
KUIPORNG is offline   Reply With Quote
Old 01-03-2007, 10:22 AM   #5
You don't get a good fire rating with paneling.It should be at least 5/8" drywall.That said you've probably got a drafty wall.
tkle is offline   Reply With Quote
Old 01-03-2007, 10:22 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Actually, this was a common practice back in the days of paneling being popular. My basement was done with just studs and paneling (no insulation). They would even spray paint the studs black at the paneling seams to visually hide any gaps between the paneling seams.
Tho: there were alot of homes where the paneling was installed over S/R too.
- Build Well -
Old 01-03-2007, 10:52 AM   #7
Originally Posted by AtlanticWBConst. View Post
Actually, this was a common practice back in the days of paneling being popular. My basement was done with just studs and paneling (no insulation). They would even spray paint the studs balck at the paneling seams to visually hide any gaps between the paneling seams.
That works for interior walls but is a no-no for exterior walls.
Old 01-03-2007, 06:43 PM   #8
.....Thanks for the correction, I realized that I missed a clue in the original poster's title:
referring to: "OUTSIDE WALLS"
- Build Well -
Old 01-04-2007, 08:53 AM   #9
J187's Avatar
Wow, thats aweful - studs and paneling huh.
Yeah, I'm not opposed to the paneling, I just wish they had gone over S/R as you say. Seems to me it would just be better regardless. I mean, Insulation is obviously the more important aspect here, but I just can't imagine that there would NOT be less drafts had the wall been drywalled first. Maybe it is not the case, but It just doesn't seem right to me that an outside wall could be very well insulated from the cold w./ just insualtion and paneling....
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
