Is This Normal??? Exposed Wood Near Foundation Of House? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 04:36 PM   #16
Civil Engineer
Rewards Points: 4,566
If you were selling a house, and someone popped off the siding to get a better look at what was underneath, how would you feel? Pretty mad I bet. Just because you are considering purchase of a house gives you no right to damage the property in an effort to improve your inspection. Hire a professional.
Daniel Holzman is online now   Reply With Quote
Old 01-04-2012, 06:42 PM   #17
Concrete & Masonry
Rewards Points: 526
At least one of the interior cracks needs further inspection from someone with experience. The two that were injected should be fine. Don't let the vertical cracks scare you away, they're in most every poured foundation out there. Very few have control joints, which are just a way to control where the concrete's going to crack.
As for the exterior let-in furring strips, they appear to be nothing more than a nailing surface cast into the foundation to aid in attaching the siding. Nothing to fret about IF that's the case indeed, but again, this is where having an experienced set of eyes look at them on-site is ideal.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
mae-ling (01-04-2012)
Old 01-04-2012, 10:21 PM   #18
Rewards Points: 2,210
To look inside a wall you can take a cover off of an outlet and pull the outlet out (turn off the power to it). you amy be ab;e to see if it has insulation.
mae-ling is offline   Reply With Quote
Old 01-04-2012, 10:48 PM   #19
Thanks again for sharing your knowledge
simiesue is offline   Reply With Quote
Old 01-04-2012, 11:01 PM   #20
Rewards Points: 13,260
If the owner or realitor does not want you checking into this what would that tell you? How fast can you run away?
This simple check is not going to damage anything.
I'd be looking for mud termite trails, rotten wood behind the siding, slats coming loose, see if they did the logical thing and added 3/4" foam inslation while they had the wall open to add insulation.
If you really are interested in this house I'll repeat my own post and another posters suggestion Hire an inspector.
Tom Struble (01-04-2012)
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
New foundation, Old house idavis Building & Construction 4 01-06-2011 05:24 AM
Water pooling next to house foundation pictures - help suggestions Steelmesh Building & Construction 8 07-03-2009 11:05 AM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 09:34 PM
