Old 03-24-2008, 11:16 AM   #1
noobie question about carport conversion
Hi all,
First, some background:
Our carport is under main roof against house. The far side is brick pillars. Back is open, front has garage door on it.
Problem is, the carport is too small for cars - the doors bash the wall when you open them - so it's just got rubbish bins and assorted crap sitting under it.
We want to close it in and use it as a workshop/box room. Would close up gargage door on front and put standard door in where it juts out a little from the house, and close up the sides and back. There's powerpoints and lights out there already.
My question is - what would be the easiest way to do this? Bricking the whole lot ourselves sounds like a bit of a mission ... would putting up cladding of some sort along sides work? Any suggestions on how we could go about this project?
Thanks, and sorry for the long post ...
emmalito is offline   Reply With Quote
Old 03-24-2008, 01:50 PM   #2
concretemasonry's Avatar
Where are you? - country, climate, etc.?
What type of structure is the roof and what is supporting it (beams, posts, etc.)
Posting a photo would help. - You can use Photobucket and others that are free.
concretemasonry is offline   Reply With Quote
Old 03-25-2008, 12:26 AM   #3
I'm in Perth, Western Australia. Climate is hot and dry, long summers, short winters.
Carport is sitting on concrete, more than 1 metre from side boundary.
Haven't got any shots of it to help though.
Front (with garage door) and pillars are double brick. Roof is clay tiles, supported by front wall and pillars and house (cut into main roof line).
Idea was to either brick in between pillars, or put up cladding of some sort between pillars (along outside).
Hope this extra info helps you to help me, as Jerry Maguire would say...
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 10:18 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 11:38 PM
Framing a carport on a detached garage nomagic Carpentry 3 05-04-2006 11:43 PM
