Noob Question About Framing Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 08:04 AM   #1
Rewards Points: 38
Noob Question about framing walls
Hello,
I bought a house and the previous owner had started a building where he kept cows. It looks like a pavilion, with a roof (new) but no sides, just support beams. I want to make it into a garage. My first question is, when framing two walls together at the corner, the 'L' where the two walls come together are not flush. How do you make them even? I'm having a hard time describing it, but hopefully someone will know what i'm talking about. My second question is what is the general spacing between studs. Is it 18 inches? Also, what kind of plywood should I use for the walls?
Thanks guys, and sorry for the dumb questions!
lmholmes11 is offline   Reply With Quote
Old 06-11-2010, 05:50 PM   #2
I might know what your talking about ....maybe
When u say the walls do not come together flush I picture two walls up where the end is like so l_ where the corners do not touch if this is the case add wood measure the gap both ways and you can probably get a piece of lumber machined to fill the gap but u actually have another much better option sheath one side with plywood extending past the gap in the corner to where it would be flush with the adjoining wall than attach a small 2 by 2 or something similar to the plywood in the gap area wich is the inside of the corner
*/ (star is there just for spacing purposes pay it no attention)
L right there than apply your plywood to the adjoining wall screwing the end into the attached 2 by 2 voila problem solved
spacing between studs is usually 16 inches but you can go 24 if u want to save cash
and id go with half inch osb ask your lumber supplier
hopefully i understood the question and hopefully u can understand the answer it would help if instead of emoticons we had buildicons if this isnt the answer u were looking for post a pic and i will use pictures to solve it
DrunkNinja is offline   Reply With Quote
Old 06-11-2010, 06:15 PM   #3
DIY staff
Rewards Points: 7,174
What you are describing sounds like a pole building without walls------
Google pole building plans---the walls are typically just perlins (horizontal 2x4's) and sheet siding.
Does this pavilion have a poured concrete floor?
Old 06-11-2010, 10:59 PM   #4
Rewards Points: 1,092
spacing
The reference above to spacing of studs in "OC", or "on center". The distance between the studs will be 13.5" on a 16" OC wall, etc. For the walls, the more I read about (and have experience w/) OSB, the more I dislike it. It off-gases noxious stuff, and it swells it if gets wet, in my experience w/ it. The newer stuff is better, but it still ain't plywood. GL. j
Old 06-12-2010, 07:10 AM   #5
Old School
Willie T's Avatar
Can you please explain how you came up with 13.5"? (Some of us get lost trying to follow this higher mathematics.)
Willie T
Old 06-12-2010, 07:16 AM   #6
kwikfishron's Avatar
Rewards Points: 410
Willie, can’t you see the 3x studs? There right there in the picture.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Willie T (06-12-2010)
Old 06-12-2010, 07:25 AM   #7
WaldenL's Avatar
Rewards Points: 268
I know I framed my rooms with 3x4s, didn't everyone else?
WaldenL is offline   Reply With Quote
The Following User Says Thank You to WaldenL For This Useful Post:
Old 06-12-2010, 07:43 AM   #8
Old School
Willie T's Avatar
Don't want to hurt anyone's feelings, but wouldn't a 3" stud setup be 13" between?
Willie T
Old 06-12-2010, 07:47 AM   #9
Rewards Points: 410
Yes, if a 3x was 3” and not 2 ½”
Old 06-12-2010, 07:49 AM   #10
Old School
Willie T's Avatar
Very quick!
Willie T
Old 06-12-2010, 12:53 PM   #11
higher math/typo
Typically, but not always, people frame with kiln dried, dimensional lumber. A "2 by whatever" is actually only (approx) 1.5" thick, or 3/4" from center to edge. Two, 3/4" distances, one from each stud, equal 1.5", so 16" OC minus 1.5" leaves 14.5" clear, not the 13.5" is mistyped above. Sorry for the confusion, and I know some of you cats were ribbing me about my math. That is OK. I retired from teaching math in '01, so I don't have to be able to do arithmetic any more! If anyone is framing w/ 3x4s, I SUSPECT that those are rough cut members, which may well be a true 3" and 4", or a tad more. Ski naked! j
Old 06-13-2010, 04:10 PM   #12
Registered User
Rewards Points: 5,492
Ah, ha. "Discreet structures" math! Now it is clear!
Be safe, Gary
Old 06-13-2010, 07:02 PM   #13
stats
My MS is in statistics, so I COULD, given enough data, leeway and time to massage, show that the difference between 13.5 and 14.5 is not statistically significant.
Old 06-13-2010, 07:53 PM   #14
Rewards Points: 410
It's all good JK
Old 06-13-2010, 08:09 PM   #15
Old School
Willie T's Avatar
It's simple. Come on try it... "I hit the wrong key."
Plays a lot better than trying some justification game.
We were just ribbin' ya. No need to struggle to come out looking good.
We all get careless and blow things from time to time.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
kwikfishron (06-13-2010)
Question regarding framing a basement wall James0816 Building & Construction 0 05-28-2010 09:41 AM
Door Framing Question biggidybankston Carpentry 4 12-10-2009 12:26 PM
re: paint noob question gramps416 Painting 8 12-07-2009 02:45 AM
Question about "cutting-in" walls? diy diva Painting 6 01-13-2009 12:24 PM
Framing Attic Walls but Roof Has SAG! luckestryke Building & Construction 1 04-27-2006 08:40 PM
