Old 06-23-2012, 11:03 PM   #16
non-square shed
It's only 8', a single slope shed roof is fine, if he wants that style, A gable can be too if he wants that syle.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
oh'mike (06-24-2012)
Old 06-23-2012, 11:05 PM   #17
non-square shed
But your trying to tell the guy to cut walls, and build walls taller, and build walls shorter, and then add walls .... plain and simple is he had the walls up and a gable roof could have been accomplished MUCH easier.
CopperClad is offline   Reply With Quote
Old 06-23-2012, 11:23 PM   #18
non-square shed
Not with non -parallel walls i'm thinking.
Unless you run the ridge at an angle? Maybe your thinking of something?
Old 06-23-2012, 11:34 PM   #19
non-square shed
The ridge is straight. The gable would just follow the angle of the wall.
Old 06-24-2012, 01:39 AM   #20
non-square shed
The center of the gable on the front would be different then the gable on the back? Or unequal slope with a slant?
Old 06-24-2012, 02:10 AM   #21
non-square shed
Think of it as a gable hip rafter. Same pitch.
The Following User Says Thank You to CopperClad For This Useful Post:
mae-ling (06-24-2012)
Old 06-24-2012, 04:07 PM   #22
Framing Contractor
non-square shed
Originally Posted by DIYinottawa View Post
OK I"ll see if I can draw something to give you a better idea.
This is how you frame that roof. Ridge down the center at 4'. Common rafters run front to back. The back side gable will act as if it were a valley.The front side would act as if it were a hip. I used a 5/12 pitch for an example. Hope this helps. The hip and valley pitch would be 4-9/16:12.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
CopperClad (06-24-2012), mae-ling (06-24-2012)
Old 06-24-2012, 04:14 PM   #23
non-square shed
Thank you for taking the time to draw him a picture. I would have done it, but not knowing the exact measurements I didn't feel it to be worth it.. Props to ya though
Old 06-24-2012, 10:56 PM   #24
non-square shed
Would work good, door would be under the eave and not the gable as long as that is ok with the person.
Old 06-25-2012, 12:03 AM   #25
non-square shed
Is having an eave over a door bad? lol imma run and tell everyone on my street !! yikes !
Old 06-25-2012, 12:21 AM   #26
Framing Contractor
non-square shed
Why is that an issue?
Joe Carola
Old 06-25-2012, 11:11 PM   #27
non-square shed
Didn't say it was bad, actually I think it would work great.
Some people may want the door on the gable end.
May look better in the yard with the way the house roof is or the phase of the moon.
I've had customers want certain things that didn't really matter, but it mattered to them.
Tags
non-square roof, shed
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Zoning issue with planned shed Ler0y Jenkins General Discussion 15 02-01-2012 01:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Poor Attic Ventilation Mechanically Challenged Roofing 15 10-23-2008 10:05 PM
