Old 06-17-2012, 09:21 PM   #1
non-square shed
build a non-square shed, to maximize the space, now having a hard time figuring out how to build the roof trusses!! HELP....
DIYinottawa is offline   Reply With Quote
Old 06-17-2012, 09:28 PM   #2
Framing Contractor
non-square shed
What are the dimensions?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 06-17-2012, 09:29 PM   #3
non-square shed
No pictures, no drawings, good luck with trying to get any replys that make since.
Old 06-17-2012, 09:30 PM   #4
non-square shed
the front is 6.5 feet wide, the back is only 2.5 feet wide!
the length on the one side is 8 feet, not sure how long the fourth side is.
Old 06-17-2012, 09:35 PM   #5
non-square shed
LOl.
Best to plan all out before starting.
Post some pics or drawings please.
Would a single slope roof work. A shed roof? Slope rafters from front to back. The front wall has to be higher then the back wall.
mae-ling is offline   Reply With Quote
Old 06-17-2012, 09:43 PM   #6
non-square shed
OK I"ll see if I can draw something to give you a better idea.
Old 06-17-2012, 09:48 PM   #7
non-square shed
I never thought of running it front to back instead of side to side... that might work.
Old 06-17-2012, 09:48 PM   #8
non-square shed
Now that's just funny.
What would make you think it was a good idea to build a shed that shape?
How is that going to maximize space?
Is this a shed you have already built?
Old 06-17-2012, 09:50 PM   #9
non-square shed
OK for a 4/12 slope build the front wall 32" taller than the back wall.
Build the side walls on a slope at the top.
Your in Ottawa? so I am guessing you need permits.
Old 06-17-2012, 09:51 PM   #10
non-square shed
I know it looks funny but my house is build into the side of a rock face, so that angle basically follows the line of the rock..... if I had to make it square it would be super tiny..... and yes I've already have all the walls up and just working on getting the roof on it.... easier said then done.
Old 06-17-2012, 09:57 PM   #11
non-square shed
OK so I understand the front and back walls, front higher and the back wall just leave it at the 8 foot height that I've already got! right?
I'm assuming you mean that that will make the side walls be on a slope like a triangle? yes? so no adjusting of heights etc...
Old 06-17-2012, 10:01 PM   #12
non-square shed
yes I'm in Ottawa but don't need a permit for such a small building
The Following User Says Thank You to DIYinottawa For This Useful Post:
mae-ling (06-17-2012)
Old 06-17-2012, 10:24 PM   #13
non-square shed
Your walls are already up so you may need to remake them some.
Build the front wall 32" higher then the back wall.
So if your front wall is 8' (96") high your back wall will only be 64" ( I'd go higher on the front so You have at least 6' (72") on the back.
Now you build the side walls, you can do this in place and toe nail, or build it on the floor, Remember because of the angle of the top plate it will be longer then the bottom plate. The front being 8' high and the back being 64" (or whatever measurement you use).
Here is the trick part. Your side walls need to be slighly more at the 64" back edge because they are 3.5" , the thichness of the back wall, short. Imagine the wall carrying through. Or build your front , then the sides, then the back to fit inbetween with it being flush on the back edge. Draw it out on paper and hopefully you will see what I mean.
Old 06-23-2012, 09:03 PM   #14
Retired Cabinetmaker
woody4249's Avatar
non-square shed
I'm lost.............
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 06-23-2012, 09:10 PM   #15
non-square shed
Please do not listen to that guy. Build the roof front to back. The ridge will be in the center of the structure.Measure from the back wall to front wall and find center. from that center point measure from your side wall to side wall. Cut your ridge to that length. From your cracked out drawing roughly 4 feet. ... Give me exact dimensions and I will tell you what to cut everything... Geez.. Ask first !
CopperClad is offline   Reply With Quote
Tags
non-square roof, shed
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Zoning issue with planned shed Ler0y Jenkins General Discussion 15 02-01-2012 01:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Poor Attic Ventilation Mechanically Challenged Roofing 15 10-23-2008 10:05 PM
