Old 04-27-2010, 12:02 PM   #1
Non Load Bearing Wall too tight?
Hey folks,
I just finished building a non load bearing wall on the second floor in my house to separate a room. I decided not to frame it since there's not much space so I toe-nailed almost all of the 2x4 studs. I put 2 top plates and 1 bottom palte. I thought I cut the studs at the correct length, but I had to hammer some of them into place with a framing hammer.
Should I take the studs down and saw off 1/8"?
Thanks for your help.
supafreeza is offline   Reply With Quote
Old 04-27-2010, 12:05 PM   #2
It was a dark and stormy
Yoyizit's Avatar
I don't see why.
The Following User Says Thank You to Yoyizit For This Useful Post:
supafreeza (04-27-2010)
Old 04-27-2010, 12:29 PM   #3
Originally Posted by Yoyizit View Post
I don't see why.
I was thinking there might be too much force between the attic and the second floor. As you can see, I may be overly cautious.
Old 04-27-2010, 12:32 PM   #4
You'll be fine. Don't worry about it.
brownmoose is offline   Reply With Quote
The Following User Says Thank You to brownmoose For This Useful Post:
Old 04-27-2010, 03:37 PM   #5
Yoyizit's Avatar
I don't know how much downward force is exerted on your floor by these overly long studs. These would be concentrated loads spaced 16" OC on your floor.
Possibly I could scrounge up a formula for column loading given how much each stud bows out, assuming they were initially perfectly straight.
Now I'm thinking you should trim them.
Old 04-27-2010, 06:23 PM   #6
There was a little bowing on some...I believe the highest being about 1/4. I had to press in the horizontal stabilizing pieces. Thanks.
Old 04-27-2010, 06:26 PM   #7
if its to long fix it...simple
The older I get the better I was
Old 04-27-2010, 07:08 PM   #8
Xtreme DIY'r
1/4" is a bit much to force in
Over time if enough force it could cause the floor to bow down or/and ceiling up that 1/4"
especially if every single stud has been forced in
Old 04-27-2010, 07:23 PM   #9
Concrete & Masonry
Or the odds are, if you bought the lumber at a big box store, it will shrink as it dries out over time. A decent friction fit is normally no problem.
jomama45 is offline   Reply With Quote
Old 04-27-2010, 09:26 PM   #10
Yoyizit's Avatar
I thought only the cross section shrunk in area, not the length.
Old 04-27-2010, 09:56 PM   #11
Moderator
Trusses?
Wall running perpendicular or with roof ?
Be safe, Gary
Clothes taking longer to dry?
Old 04-28-2010, 12:45 AM   #12
Thanks a bunch for all the responses guys. I just went to the house and took out the nails from the bottom and used a saw to remove about 1/8 of an inch out. It's seems all good now.
Once again, thanks for all your input.
Old 04-28-2010, 10:53 AM   #13
Yoyizit's Avatar
I found the formula for column buckling/deflection but I couldn't get the same answer as the example problem. Oh, well. . .
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 07:19 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
load bearing wall under king post trusses jimby Carpentry 5 01-02-2009 06:15 PM
load bearing wall no more grant Building & Construction 5 10-14-2007 09:50 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
