-   -   Non Load Bearing Wall too tight? (http://www.diychatroom.com/f19/non-load-bearing-wall-too-tight-69971/)
supafreeza 04-27-2010 11:02 AM
Hey folks,
I just finished building a non load bearing wall on the second floor in my house to separate a room. I decided not to frame it since there's not much space so I toe-nailed almost all of the 2x4 studs. I put 2 top plates and 1 bottom palte. I thought I cut the studs at the correct length, but I had to hammer some of them into place with a framing hammer.
Should I take the studs down and saw off 1/8"?
Thanks for your help.
Yoyizit 04-27-2010 11:05 AM
I don't see why.
supafreeza 04-27-2010 11:29 AM
Originally Posted by Yoyizit (Post 434275)
I don't see why.
I was thinking there might be too much force between the attic and the second floor. As you can see, I may be overly cautious.
brownmoose 04-27-2010 11:32 AM
You'll be fine. Don't worry about it.
Yoyizit 04-27-2010 02:37 PM
I don't know how much downward force is exerted on your floor by these overly long studs. These would be concentrated loads spaced 16" OC on your floor.
Possibly I could scrounge up a formula for column loading given how much each stud bows out, assuming they were initially perfectly straight.
Now I'm thinking you should trim them. :eek:
supafreeza 04-27-2010 05:23 PM
There was a little bowing on some...I believe the highest being about 1/4. I had to press in the horizontal stabilizing pieces. Thanks.
tpolk 04-27-2010 05:26 PM
if its to long fix it...simple
Scuba_Dave 04-27-2010 06:08 PM
1/4" is a bit much to force in
Over time if enough force it could cause the floor to bow down or/and ceiling up that 1/4"
especially if every single stud has been forced in
jomama45 04-27-2010 06:23 PM
Or the odds are, if you bought the lumber at a big box store, it will shrink as it dries out over time. A decent friction fit is normally no problem.
Yoyizit 04-27-2010 08:26 PM
I thought only the cross section shrunk in area, not the length.
Gary in WA 04-27-2010 08:56 PM
Trusses?
Wall running perpendicular or with roof ?
Be safe, Gary
supafreeza 04-27-2010 11:45 PM
Thanks a bunch for all the responses guys. I just went to the house and took out the nails from the bottom and used a saw to remove about 1/8 of an inch out. It's seems all good now.
Once again, thanks for all your input.
Yoyizit 04-28-2010 09:53 AM
I found the formula for column buckling/deflection but I couldn't get the same answer as the example problem. Oh, well. . .
