Non-load Bearing Wall Glued To Subfloor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 02:58 PM   #1
Non-load bearing wall glued to subfloor?
Hi,
Should Non-load bearing walls be glued to the subfloor? I bought a house that has a lot of squeaks and crackles around some of the non-load bearing walls. I narrowed down the problem to it being that the base of the wall constantly rubs against the subfloor. I was able to verify my findings by adding wooden wedge spacers between the base of the wall and the subfloor and the noise is reduced tremendously.
How can I fix this. Obviously leaving the spacers there is not a solution since the carpet/wooden floor will not fit if I leave it there.
robtrevino is offline   Reply With Quote
Old 02-03-2011, 03:44 PM   #2
Registered User
Termite's Avatar
Gluing walls' bottom plates to the floor sheathing isn't something you'll see done by professionals very often. It definitely isn't required.
You may need to open the sheetrock a little to do it, but a few strategically placed screws would draw the wall and the floor sheathing together and stop the squeaks. Ideally, screw down through the plate into a joist beneath.
The Following User Says Thank You to Termite For This Useful Post:
oh'mike (02-03-2011)
Old 02-03-2011, 06:39 PM   #3
Thanks!
Old 02-04-2011, 07:15 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,... If you've got a cellar, you might be able to screw Up from below....
Old 02-04-2011, 07:37 AM   #5
Rewards Points: 5,336
Originally Posted by robtrevino View Post
Hi,
Stud walls arebuilt on subfloors, not next to them. It sounds like someone added another layer for some reason but didn't leave an expansion gap. You can cut a gap(using a jamb saw) into the subfloor so it has some breathing room.
Ron
Passthru in Load Bearing Wall - Graphic Included Evil Scotsman Building & Construction 13 11-08-2010 02:07 PM
Load Bearing Wall Removal Question! Please Help! Evil Scotsman General DIY Discussions 2 10-25-2010 04:52 PM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 12:17 PM
Load Bearing Exterior wall however it has an overhanging porch rhoton1 Building & Construction 2 03-16-2009 06:19 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 07:43 AM
