Non Load Bearing Partition Wall Parallel To Sloped Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 04:31 AM   #1
Non load bearing partition wall parallel to sloped ceiling
I am looking to remodel a bathroom that would require framing a 5 foot interior wall. The bathroom in a second floor addition with an 8' ceiling that slopes down to a 4' knee wall. The wall will be within and run parallel to the slope (no joists). Would I rotate the top plate to lay flush with the pitch or cut an angled strip to square up the top plate or are neither of these good ideas.
Thank you
poorstudentOU is offline   Reply With Quote
Old 05-26-2011, 06:23 AM   #2
DIY staff
Rewards Points: 7,174
Typically the studs are angled and the top plate is too.
Ripping an angled filler could work but sound like a lot of extra work.---Mike---
Old 05-26-2011, 10:10 AM   #3
That's what I was thinking I'd need to do. But on the off chance that I can get ahold a table saw I think I'll try ripping that angle to simplify the rest of the cuts if it's not considered bad practice
Old 05-26-2011, 10:20 AM   #4
DIY staff
That's ideal---however the top plate will need to be cut from a 2x6 as an angled 2x4 won't be as wide as the studs.
Old 05-26-2011, 10:33 AM   #5
is this following the slope-parallel, or perpendicular to roof slope
The older I get the better I was
determining opening in load bearing wall RonGage Carpentry 0 11-05-2010 10:24 AM
Is this wall load bearing - pictures attached jen5219 Building & Construction 16 08-01-2010 01:17 PM
Load Bearing Wall Issue? iggy913 Building & Construction 1 07-28-2010 07:45 PM
Load bearing wall in basement Ezekiel Building & Construction 3 11-12-2008 10:23 PM
Load Bearing Wall rpatterson Building & Construction 2 10-29-2005 08:43 AM
