Non Load Bearing Header - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 08:12 AM   #31
Originally Posted by spring3100 View Post
You are putting bottom runners on those doors,this should prevent sagging over time.
I made a folding door arrangement (4 doors) across a balcony using Johnson folding door hardware,Header above was 2 2 by 4's.
It has been in place about 5 years with no sagging,doors were fire rated and the four together weighed 140 pounds.
Probably shouldn't have asked my wife to lift them into place,but they wanted the vote!!! LOL
I appreciate your advice. I've decided to stick with the box beam idea.
In order to get the depth I need with lumber stood vertically, I'd have to rip plywood shims, etc...
I like the idea of all 2x6 lumber it will simplify the construction. I'd probably use a couple of flat 2x6s if I was using bi-folds as the weight really pivots from the very corners of the header and will never bear on the middle. With these sliding doors, it's feasible to have all 3 doors hanging from the middle of this beam.
It doesn't appear to me that these bottom guides have any intention of supporting the weight of the door at any point.
GottaFixIt is offline   Reply With Quote
Old 01-13-2012, 12:50 AM   #32
Rewards Points: 2,212
Your doors are entirely supported by the top, those just keep doors from rubbing each other.
mae-ling is offline   Reply With Quote
load bearing walls rvesci General DIY Discussions 4 12-28-2010 09:51 PM
Load bearing wall! Newtsjetson Building & Construction 2 12-19-2010 07:46 AM
Non load bearing wall door header? nocarpenter Building & Construction 10 06-11-2009 04:16 PM
Is this Load Bearing Wall remodel-virgin Building & Construction 16 05-11-2009 04:25 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
