Non-combustible Structural Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 12:10 AM   #1
Rewards Points: 87
non-combustible structural framing
I am remodeling my basement and have insulated most of the walls with XPS over cinder block and a cedar framed false wall inside that.
However there is one more area where the existing fireplace is that I want to insulate. It looks something like this:
I plan on putting an applicable non combustible insulate such as Roxul Rockboard over this wall to insulate it.
I know with proper head shields and double wall chimney pipe I could get my chosen wood stove quite close to a unprotected surface, however I would like to make the entire wall non-combustible.
Since Roxul Rockboard is not structural I need some kind of non-combustible studs or structural elements to use in the wall.
Any suggestions on how to best go about this?
hellonoko is offline   Reply With Quote
Old 05-03-2012, 12:32 AM   #2
Rewards Points: 636
if wanting to use wood try pyroguard but get out your wallet and hold on.
http://www.frtw.com/?q=node/13
or look at using metal studs "dietrich or clark" and cement board or drywall
http://www.clarkdietrich.com/products
http://www.usg.com/sheetrock-firecod...um-panels.html
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-03-2012, 01:28 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
light gauge metal framing studs would work
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-03-2012, 04:14 PM   #4
Rewards Points: 87
@GBrackins
Are light gauge metal framing studs non combustible or just fire resistant?
Old 05-03-2012, 04:30 PM   #5
GBrackins's Avatar
they will not ignite like wood studs, so they are non-combustible. however, being a thermoplastic as steel is, they can be affected when exposed to fire or increased exposure to increased temperatures as found in a fire. Steel expands when exposed to higher temperatures.
light gauge steel studs are routinely used in fire wall construction, and often in commercial construction. Galvanized steel studs will resist corrosion, and are more dimensionally stable than wood when exposed to higher moisture content as typically found in basements.
Gary
Old 05-03-2012, 04:55 PM   #6
Rewards Points: 87
@GBrackins
Thanks, and I suppose I can just get a higher/ very high gauge of steel stud if I want it to be more heat resistant.
Old 05-03-2012, 06:31 PM   #7
GBrackins's Avatar
well if they can work as part of a fire wall preventing the spread of fire from one area to the next I'm sure they would work in your application.
Gary
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Shower framing - structural question masmalone Building & Construction 2 01-03-2011 05:15 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
