Noisy Neighbors Necessitating Bedroom Soundproofing...HOW?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 01:14 AM   #1
Noisy neighbors necessitating bedroom soundproofing...HOW??
We have noisy neighbors who are keeping us awake at night. Since we're remodeling the master bedroom anyway, we want to suppress sound in its two exterior walls, as well as one interior wall (plus one exterior wall in the adjoining master bath). The bedroom gets cold in the winter and hot in the summer, and I recently updated the attic insulation (which helps a bit with temperature). Our walls are 2"x4", and we have a small, top-of-the-line window in the room (which we know will likely always leak sound to some degree). Thus, we just want to do the best job we can at soundproofing without going overboard.
I've read about the following on this site and am definitely a drywalling, insulation, and soundproofing novice. I'd appreciate anyone's perspective about what might work best...especially for 4" exterior walls.
--quiet rock
--dampening compound
--green glue
--sound sealant
--clips
--blue jeans insulation
--high density fiberglass
--cellulose batts
--roxul
--anything else??
We'd just love to know what strategy or combination is most effective for suppressing the sound of nearby rumbling car motors, etc. I'd like to do what I can, and I'll be hiring a local company to handle the drywall once everything within the wall is complete. Any guidance is sure appreciated!
johngerritlasko is offline   Reply With Quote
Old 03-16-2013, 01:26 AM   #2
Smile
I know noisy neighbours are so annoying. I recommend you to use carpets, they do a surprisingly good job of absorbing sound in the home and also use heavy curtains. I think this would reduce some of noise. Also request your neighbours to slow down noise.
nisha02 is offline   Reply With Quote
Old 03-16-2013, 02:59 AM   #3
Rewards Points: 1,092
search here for noise reduction, sound proofing, etc. there are many threads on this. basically, fill all air gaps, install dense insulation like roxul, two layers of sheetrock or quietrock, heavy drapes, good windows (double or triple pane), bushes between you, etc. call the heat, too.
Old 03-16-2013, 05:09 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
Start outside....shrubs and/or a solid fence will do wonders.
What kind of noise? Kids? Yelling? If it's after 10pm...there is a certain expectation of quietness.
Old 03-16-2013, 12:15 PM   #5
Rewards Points: 194
I live in a corner ranch home and the car sounds were frustrating and the rooms were too cold/warm depending on the season until I ripped down the the exterior wall's dry wall and stapled in Owens Corning R-13 Kraft 3 1/2 in x 15 in. and redrywalled. I did one room at a time with new paint, carpets, oak baseboard, and new window casings until every room was like new again. The sound and heat/cool issues are much better now.
Larryh86GT is offline   Reply With Quote
The Following User Says Thank You to Larryh86GT For This Useful Post:
johngerritlasko (03-17-2013)
Old 03-16-2013, 12:46 PM   #6
Roofmaster
Rewards Points: 2,172
Larry, do you mean to tell me that someone built a home in Buffalo, NY with no insulation it the walls????
Old 03-16-2013, 12:51 PM   #7
Roofmaster
Glass seems to really stop sound. I wonder how glass bead poured into the wall would do? You would have to air seal all outlets etc. Frankly, I am very surprised you don't have a block masonry wall between dwelling units. This is usually required for fire code. Masonry really quenches noise.
Old 03-16-2013, 01:36 PM   #8
Rewards Points: 194
It was built in 1953 and there was not a bit of insulation in the walls. They did put thin, pretty much useless, batts in the attic that was their entire effort to insulate the house. There are a lot of these ranch homes around here and their gas bills are pretty high in the winter.
Old 03-18-2013, 12:33 AM   #9
Further clarification (thanks everyone!)
Thanks for the ideas, thus far, everyone! Here are a few more details to clarify some questions.
We live in a house (not an apartment) in Nebraska, have carpeting and new triple-pane windows, have newly installed landscaping (& can't install a noise-reduction fence or further landscaping in the affected area), and the noise from the neighbors two houses down has included loud car engines and occasional tire screeching at random times throughout the night (even 3-5 a.m.). We have spoken directly with the neighbors, and other neighbors and we have called the police several times. We're being assertive in that way. The engine-revving from a fairly-major street about 1/2-block away also interrupts sleep at times.
Thus, since we're remodeling the bedroom, we're considering re-doing the walls. Currently, we presumably have our two outside walls constructed with masonite (or the like) in good shape on the outside, fiberglass insulation, and drywall. Our house is 37 years old, so I'm guessing the fiberglass has settled in the walls.
Do you believe it'd be worthwhile (expense & effort) to remove the sheetrock and the old insulation, install either fiberglass or noise-suppressing insulation, and then install a double-layer of quietrock? How is the double-layer handled with door trim and window trim?
Iíve read multiple other strings on this website over several hours, and have found little addressing soundproofing of OUTSIDE walls, other than what you all have written here. Iíll look into the ideas suggested, and we so appreciate any insight anyone else can offer for other options we can/should consider.
Again, thanks everyone!!
John
Old 03-18-2013, 09:09 AM   #10
Rewards Points: 6,652
If it is noisy Sex, just make sure that you congratulate them each morning when you see them, make it known that you are really proud of them, by embarrassing them in as many ways as you can. After a while, they will get the message and start holding it down.
Old 03-18-2013, 10:10 AM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
If they are married, they are not doing the dirty.
Staggered walls, Quiet Rock, etc are all good solutions.
Old 03-18-2013, 11:04 AM   #12
Roofmaster
What is "Masonite or the like"? It sounds to me that your house was made by a cardboard box manufacturer trying to break into the housing market.
As to your neighbors two doors down, a couple of RPG's comes to mind. Inexpensive and effective. You can get them from Russia. Roofing cap nails are also effective sprinkled liberally in their driveway. They stand pointy side up most of the time when you broadcast them. A few flat tires ought to get the message across. If not, use suggestion 1. I guess you can tell that I have very little tolerance for A holes.
As to your house, I dont see why you would want to remove the existing drywall. Just cut out a strip along the top, seal all outlet boxes with foam, and pour glass bead insulation into the cells. Reinstall the strip of drywall and add another layer right over the top. Dont forget to transfer the stud locations to the ceiling so you can plumb down for attachment of the new drywall.
Good luck, and good hunting.
The Following User Says Thank You to jagans For This Useful Post:
johngerritlasko (03-18-2013)
Old 03-18-2013, 12:01 PM   #13
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
What time of day?
Maybe just not with each other.
In which case Gregzoll's suggestion should work wonderfully.
Old 03-18-2013, 04:23 PM   #14
Didn't think about that but given today's ever shifting morality compass...you are probably right.
Old 03-18-2013, 06:25 PM   #15
Roofmaster
Eric, I gotta use that one. "Ever Shifting Morality Compass" You got that as his excuse from Willie Clinton when he was in the oval office with ML right?
Thats Classic.
Tags
bedroom , insulation , proof , sound , soundproofing
Basement bedroom framing options Mesoneer Remodeling 8 01-24-2012 12:47 PM
Cold bedroom chronojosh Building & Construction 9 12-23-2011 03:43 PM
Extend garage into unwanted bedroom janmullins Building & Construction 5 09-25-2011 11:43 PM
Very noisy radiator in bedroom...Need help and sleep. Levib2004 Plumbing 1 01-17-2009 02:29 PM
