Noisy Basement Apartment - Ceiling open to subfloor upstairs
First question, is this unit zoned as a rental, and if so does it meet all the zoning, code and life/safety requirements (for example, emergency egress requirements)?
When I find the sorts of conditions you describe at an inspection, the odds are better than even there will be significant number of other sub-standard and often unsafe conditions, and often use of the basement as a rental unit is not allowed in any case.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
