Noise Reduction Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2010, 02:15 PM   #1
Rewards Points: 640
Anyone know of companies that make noise deadening (reduction) windows? Our master bedroom right now just has Low E Gorell double hung windows and the sound from the road about 50 ft away just goes right through them (but then the seal on them must of broke because there is water between the two panes of glass, and part of the metal seperator streip inside the panels is rusting.....) not sure if Gorell makes them or not? anyone know if Gorell does? (since the company is in my town easiest to get them) but any other companies out there that make them too for repalcements? thanks
BlueBSH is offline   Reply With Quote
Old 05-19-2010, 01:47 AM   #2
Rewards Points: 1,092
never heard
I've never heard of sound reduction as being a selling point for a window, but surely triple pane, low-density gas filled would help. You still have the frame to deal w/ though. I think you pointed out part of your problem; more dense air, and therefore a better conductor, is in you window. Call your local company, and let us know what you learn. thanks. john
Old 05-19-2010, 05:10 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
Almost all window companies offer Argon, Krypton, or a combination of the two inert gasses to aid in noise/heat transferrance reduction. Gorell is one of them. Since they are local for you, I would give them a call and see what they have to offer you.
Man of many hats
wrangler is offline   Reply With Quote
Old 05-19-2010, 11:45 AM   #4
Totally screwed together
This is what you are looking for:
http://www.soundproofwindows.com/
They don't list prices on their website (due to stickershock!) but normal sizes start out at $400 and go up from there.
It sounds like alot, but for one window and the peace of sleep, it may be worth it!
xxPaulCPxx is offline   Reply With Quote
Old 05-19-2010, 12:41 PM   #5
They installed a lot of these types of windows near Logan airport in Boston to reduce noise & be a good neighbor to residents
Old 05-20-2010, 11:46 PM   #6
Rewards Points: 410
Gorell has a triple pane armor glass they claim to offer sound control.
You should e-mail them or call them up.
http://www.gorell.com/
High Gear is offline   Reply With Quote
Old 05-24-2010, 09:08 PM   #7
And you can get this guy to help you test them
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 01:17 PM
Floor Joist Types (Noise Reduction) bparise Carpentry 10 01-19-2010 05:24 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
Noise Reduction of Original HardWood Floors artist082483 Flooring 2 10-09-2008 04:57 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
