No Vapor Barrier In Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2014, 05:27 PM   #1
Rewards Points: 268
no vapor barrier in ceiling
Today I took down a 2x4 piece of drywall in the ceiling of my kitchen. I noticed, when it started raining loose fiberglass, that there is no vapor barrier between the drywall and attic insulation.
My question is, since I am going to add more insulation on top of what is there, is there a specific kind of material I should use? I am not going to remove the existing insulation, so what ever I have installed will be blown in on top of existing fiberglass. Thanks Rich
packer_rich is offline   Reply With Quote
Old 07-25-2014, 03:40 PM   #2
Rewards Points: 336
The most important thing at this point is that you don't add insulation that has a vapor barrier on top of insulation that doesn't. This would trap moisture between the drywall and the new insulation. If you are adding blown-in insulation, you won't have this problem.
JKeefe is offline   Reply With Quote
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
