No Room For A Hanger? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 07:08 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,344
No room for a hanger?
I'm need to stiffen up my kitchen floor for preparation of slate tiles. Part of this project includes new joists around a chimney. The chimney projects out into the kitchen area. In this case, Ive got a double Microlam joist running 11' 6" on each side and a double LVL header between those spanning the width of the chimney which is just short of 5'.
How do I attach the header since one side of it will be right up against the chimney?
TIA
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 03-18-2008, 05:30 PM   #2
I have gas!
I guess my only option is 3/8x6" lag screws and maybe a framing anchor on one edge.
I can't think of any other way to give the header the support it needs.
Old 03-18-2008, 09:06 PM   #3
remodeling pro
The header should not be laid right against the chimney anyway, so you should be able to space it out far enough for the flange of a joist hanger . You can let the sub floor overhang the header by a bit to get it closer to the chimney.
troubleseeker is offline   Reply With Quote
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 09:00 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 05:34 PM
Room to Room Vent cjpilot HVAC 5 12-02-2007 08:53 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
