No Rim Joist? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 09:18 PM   #1
No rim joist?
after reading here about the benefits of insulating your rim joist, i decided to do mine, but when i went to inspect it i didn't see a rim joist area. cuts were made in the cinder block and the floor joists appear to sit directly inside those cuts on top of the cinder block foundation. there is no cavity to insulate like ive been seeing with normal rim joists. You can see in the pictures how the joists are sitting on the block and that there is no joist behind the block. is this normal?
dc350 is offline   Reply With Quote
Old 10-19-2012, 09:26 PM   #2
Rewards Points: 672
Picture would be best.
Do you know what the rim joist is?
You believe the joists are sitting in "cuts" in the cinder block? My joists are sitting ON the cinder blocks with a cement mixture poured between the joists against the rim joist. Could this be what your seeing?
B
Beepster is offline   Reply With Quote
Old 10-19-2012, 09:38 PM   #3
i posted some pictures. i don't see any wood at all behind where the joists are sitting
Old 10-19-2012, 10:08 PM   #4
Rewards Points: 2,212
Haven't seen that before.
I have seen concrete poured between the floor joists, but still a rim joist.
mae-ling is offline   Reply With Quote
Old 10-20-2012, 07:03 AM   #5
DIY staff
Rewards Points: 7,174
It looks like you have an older balloon framed structure---and someone added those cinder blocks long after the structure was built---
How about a picture of the house from the outside?
Age of the house?
Old 10-20-2012, 07:43 AM   #6
DIY staff
Disreguard my post-----that picture was confusing before I had enough coffee-----
I see now that the cinder block is a wall and the framing is resting on the blocks----
Nothing unusual about that method of construction-----
insulating that area? I'll leave that for others----
Old 10-20-2012, 08:34 AM   #7
Rewards Points: 13,750
Looks like expanding foam is about all your going to be able to get in there.
Unpressure treated wood in direct contact with concrete, no termite shield.
Old 10-20-2012, 09:30 AM   #8
Rewards Points: 236
in my house, that area was filled with bricks & mortar. but i do have a rim joists. so, i wouldn't doubt that you do to, you just can't see them. i can't see mine either, except for where there is some bricks busted out.
Fix'n it is offline   Reply With Quote
Old 10-20-2012, 10:00 AM   #9
AHH, SPANS!!!
Rewards Points: 1,166
does the concrete block go up tight to the underside of the sub flooring? You probably have a rim joist on the other side of the block...
hand drive is offline   Reply With Quote
Old 10-20-2012, 11:47 AM   #10
Bombastic Idiot
notmrjohn's Avatar
Rim or not, looks like the sill covers the blocks, the blocks are liable to be filled with mortar, don't see any way to insulate above the block and house. If blocks are hollow, you mite be able to fill them with foam, but i don't think minimal benefit would be worth drilling holes thru floor to see if hollow, or possible structural damage by drilling thru block.
Can you remove some siding outside and get a look from that side?
Seal gaps between blocks, sill, and joists with caulking and/or miniamal expanding foam.
Insulating foundation walls, between joists and with what material, type and location of vapor barrier, depends on several things.. Basement? Finished or unfinished? Heated unheated? Dry or moist? Crawl space? Vented or unvented? Ground covering moisture barrier? Climate of your area. Soil type, moisture in soil around and under house.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-20-2012, 01:20 PM   #11
spray insulation would be best.
Next is probably low expanding foam in the gaps, Styrofoam sealed with low expanding foam on all sides to floor above and joists.
How are you insulating the rest of the basement?
Better to cut batts than scrunch them to open up space at rim joist? darlingm Insulation 2 08-30-2011 12:26 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
