No Drain Tile To Tie Egress Well Into - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 11:29 AM   #1
No Drain tile to tie egress well into
Hi we just dug an egress window well planing to tie into the drain tile of our recently aquired home ( we have two sump pumps) Im below the footing now with no drain tile in sight? just 3/4 stone am I wrong to assume this is a bed for water to flow and just grade my whole with stone without tying into any drain tile? Im 94" down and my boys are threatening to run away from home If I get the shovels out any more ... any suggestions would be appreciated! thanks ... By the way our home is 30 years old and it was contractor owned and built and there is no info at the building inspectors and of Course the builder is dead.... Im now 18" below the foundation and digging under the footings anyone know the standard for how far under the footings drain tile are laid?
mountain23 is offline   Reply With Quote
Drain Tile Recommendation: guha5006 Plumbing 2 08-05-2010 05:35 PM
How to Finish Tile Floor around Drain Hole atm Tiling, ceramics, marble 3 09-12-2009 11:39 AM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
