Newbie Bolt Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 11:41 PM   #1
newbie bolt question
Hi everyone,
Simple question, are "through bolts" the same as hex bolts? I am reading my code requirements for decks and they mention to use "through bolts".
But today I was at Home Depot and in their hardware section they did not have anything called through bolts. Does it go buy a different name perphaps hex bolt?
Thanks!
max_wonder00 is offline   Reply With Quote
Old 10-23-2010, 01:43 AM   #2
Rewards Points: 558
A through bolt is any bolt which passes completely through all the thickness or layers of material which it holds together. It will also have a nut and washer assembly or you might have to purchase them separately.
Hex bolts are also known as hex cap screws or machine bolts and they can be used as “through bolts”
epson is offline   Reply With Quote
Old 10-23-2010, 02:46 AM   #3
jlhaslip's Avatar
Rewards Points: 2,866
Hex bolts, Plow bolts and Carriage bolts are all examples of 'through' bolts.
Lag bolts are not 'through' bolts unless they are too long.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-23-2010, 03:22 PM   #4
All you need to be sure of on your through bolt is that it is thick enough compared to the length. For example, I would you a 1/2" bolt if it was 6" long.
Polywanna is offline   Reply With Quote
Tags
bolt
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Newbie Question bjp Introductions 2 10-09-2006 02:37 AM
