Newb Needs To Know The "Art Of Spackling" - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-28-2008, 10:59 AM   #1
Rewards Points: 81
newb needs to know the "Art of Spackling"
Hi, i had to take down ceramic tile in my bathroom behind the vanity. It was glued up with mastic or some sort of adhesive. Well i had a real mess behind that sink and have some deep gauges. I managed to sand down the entire surface using my electric sander. Now i am ready to spackle the area, only thing is i really suck at this.
Can any of the pros give me some pointers at spackling?
Didn't know if this should be in the painting section or not?
mayhem69 is offline   Reply With Quote
Old 12-28-2008, 12:18 PM   #2
I'd rather put on ten layers of thin spackle than have to sand it down once, I hate that dust.
Now I use a wet towel over a 2x4 and quickly wipe the surface smooth. If the spackle starts to soften and pull away, I'll let it sit for an hour and then start over.
For big fill areas, I pack it in thick, and give it a few days to shrink and crack. For the finishing, add a little water to the mixture and stir until it flows nicely. Use a 10" spreader, and only 2-3 strokes only at 45deg to each other. Let dry and repeat.
Stillwerkin is offline   Reply With Quote
Old 12-28-2008, 11:06 PM   #3
NJ Renovator
R&RRenovators's Avatar
Believe it or not you can add some dishwashing liquid to the spackle
R&RRenovators is offline   Reply With Quote
Old 12-29-2008, 09:23 AM   #4
If the drywall is really messed up it might be easier to cut out a section (say 3' by 5') and replace with wonderboard or hardibacker. That way you've only got the four seams to tape and mud, it will be easier to work with, and it will be more water resistant than normal drywall. Not sure if this helps but it might be easier in the long run. Best of luck.
Skipperjj is offline   Reply With Quote
newb from WV... OmegaBunny Introductions 4 09-17-2008 01:24 PM
Newb from WV CharlieHo Introductions 1 08-17-2008 08:25 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
need help wiring a massage chair - newb Shack Electrical 2 05-28-2008 11:01 PM
