Old 09-12-2010, 11:10 AM   #1
New window in old frame
I may have screwed up the custom window measurement, or not. I am trying to fit a new window w/ frame into the frame of the old window (old frame still in place). As a result, I have a window with two sills (see photo). I want to keep the old will. Should I simply cut off the sill from the new frame?
The other alternative is to order a new window w/o frame to replace existing. This will also avoid coming short on the 4 1/2" trim (no brick molding) with the shingles.
Another option is to order a low-E pane and affix, somehow, to the old single unit window (6 panes). Has anyone done this before?
KurtP
KurtP is offline   Reply With Quote
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Retrofit window - void between vinyl and alum frame?? pcl586 Remodeling 13 05-20-2010 07:24 PM
Installing window AC in metal frame sato HVAC 10 08-08-2009 10:15 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
