New Window In A Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2009, 11:45 AM   #1
New Window in a Load Bearing Wall
Hi Folks
Apologies if this was already posted or if I am in the wrong section. I did a search but could not find anything appropriate.
Anyway just a quick question:
I am currently looking at buying a 2 storey house which is concrete built.
The house is strucurally complete now but unfortunately the Kitchen area is quite dark as there is no window near where the Kitchen Presses should be. For some reason the Builders decided not too put in a window where all other detached houses in the estate have it.
My question is. How much trouble would it be for a builder to put in a Small Window into a load bearing wall. The builder has said it is too messey a job.
How difficult would this be for the builder. Is this a standard operation or is it something best avoided. We dont want to push the builder on this, if it is an unreasonable demand.
Any general info on this and what would be involved would be appreciated.
Thanks for your help.
Cheers Dave
pleuraxeraphim is offline   Reply With Quote
Old 04-15-2009, 12:15 PM   #2
Is the wall brick or stone etc?
That can be messy
But a wood framed wall is fairly simple & straight forward
This is on the 1st floor?
I've retrofitted windows into walls - doesn't take that long if its not a big window
Old 04-15-2009, 01:02 PM   #3
Well the walls are made of concrete bocks. Id imagine it would be difficult.
Old 04-15-2009, 01:51 PM   #4
by code you would have to install a lentel which in my case was steel angel above the window extending past the frame and into the block.It can and is a messy and hard job to do after the wall is already up.If it is planned for and put in durring the building it anit no big deal .You might just be better off putting in more lights in the kit.
clasact is offline   Reply With Quote
Old 04-15-2009, 04:54 PM   #5
Hi Lads. Thanks a million for tha advice. Appreciate your replies. Might leave well enough alone and get some extra spot lights put in. Cheers Dave
Old 04-15-2009, 07:08 PM   #6
Putting a window in a concrete block wall is very easy to do with the right equipment and know how. It can be messy if you don't tape off the air, use dust extraction, and don't use drop cloths. You should have no problem installing the window as long as you get a decent contractor who has done this a few times before. Lintels are easily retrofitted.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Removing part of load bearing wall? destroyer427 Building & Construction 11 04-08-2009 02:24 PM
Load Bearing Wall??? please help shenmon Building & Construction 6 01-24-2009 10:07 AM
load bearing wall under king post trusses jimby Carpentry 5 01-02-2009 05:15 PM
Load bearing Wall? flyndave2002 Building & Construction 19 02-22-2008 11:24 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
