New Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 03:05 PM   #1
Lightbulb
New walls
Hi, I'm in the process of designing a new house and have decided on using 2x8 lumber for the frame rather then the traditional 2x6. Two reasons, one, It's not that much more expensive and two, I can have upto R30 insulation in the walls.
MY question is this, has anyone done this before and if so, what if any were the problems. I know 2x6 is what is normally used but I am challenging the norm and future proofing my investement.
Phil
teflonphil is offline   Reply With Quote
Old 03-06-2010, 04:16 PM   #2
go for it!
should be good for our economy.
Big Bob is offline   Reply With Quote
Old 03-06-2010, 04:58 PM   #3
remodeling pro
The only annoyances I have seen with really thick walls is with exterior doors. If they are inswinging units, and hung in usual scenario from the outside so that the thresholds will be in correct exterior location, you can add jamb extensions to make up for the wall thickness, but this puts the hinges several inches deep into the wall (even if you order jambs for 2x6 walls); thus the doors cannot swing open more than 90 degrees, and the latches leave drag marks across the jamb extensions.
I would use outswing units wherever possible, like onto patio or side/back porches. This is not ok for front entry unit, so you will have to work with a local mill supply shop to manufacture a unit for you with a decent extra wide threshold. Ask about prices for all of the exterior units;they may bid their labor costs lower for several units as opposed to just one custom unit, and if reasonable you can go with all inswings if desired. Window sills will have to be job fabricated to accomodate the depth, but that is no problem for trim guys.
troubleseeker is offline   Reply With Quote
The Following User Says Thank You to troubleseeker For This Useful Post:
teflonphil (03-08-2010)
Old 03-06-2010, 05:01 PM   #4
Registered User
Rewards Points: 4,924
You will get R-2 more going the bigger studs. Rather go 24" advanced framing for a much better R-value for the whole wall assembly: http://www.coloradoenergy.org/procor...f/r-values.htm
http://www.rvaluehomes.com/rvalue.htm
http://www.advancedenergy.org/buildi...x4_or_2x6.html
Location, Alaska?
Be safe, Gary
Old 03-06-2010, 07:33 PM   #5
DIY staff
Rewards Points: 7,174
I say,great you will enjoy a more comfortable house and a life time of lower fuel bills.
You will have ti special order your exterior doors--the door shop will build them with wider sills and jambs.
You may have the doors swing in with no problem as the extensions are on the out side.
---Mike--
Old 03-06-2010, 07:41 PM   #6
I would add 1 or 2 rows of horizotal blocking to eliminate bowing/movement. I ralize that is a thermal break so maybe altenating 2x4 or6 to allow insulation
The older I get the better I was
Old 03-06-2010, 09:04 PM   #7
firehawkmph's Avatar
Rewards Points: 1,800
Phil,
Did you look at sips panels at all? Sounds like it would be right up your alley.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-08-2010, 07:25 PM   #8
Thumbs up
Thanks for the thoughts. I did look at SIP panels but they are cost prohibitive. I will be using blocking between studs, but with a thermal barrier on the outside under the siding, the increased amount of timber isn't a problem.
Phil
Old 03-09-2010, 10:09 AM   #9
jlhaslip's Avatar
Rewards Points: 392
Keep the 2 x 8 plates, but use a double wall of 2 x 4's for studs.
Stagger/offset the interior and exterior studs to avoid thermal bridging, like a parting wall.
Handle the doors/windows as discussed.
A friend did this and their house is toasty warm in the winter and stays cooler in the summer. Insulation works during hot and cold.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Tags
dimensions , insulation , lumber , walls
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 10:50 AM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
