New Wall Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 09:14 AM   #1
Rewards Points: 131
new wall insulation question
is it necessary to remove existing silver foil fiberglass insulation anchored to concrete when building new basement wall. can i keep there, build the new wall against the old insulation, then put a new insulation between all studs? i figure this will have combine R value of both insulation.
s002wjh is offline   Reply With Quote
Old 01-04-2012, 09:49 AM   #2
Rewards Points: 13,690
The insulation never should have been glued to the foundation in the first place and it's backwards if the vaper barrier is on that side.
Old 01-04-2012, 10:17 AM   #3
Rewards Points: 131
it was anchor to the foundation using concrete screws. the silver foil(not the vapor barrier, since it can pass through air) is facing toward inside the house. this was done in a Unfinish basement. however i'm planning to build a finished basement.
so order from fundation to wall
1. concrete fundation
2. old/ existing fiber glass with reflective cover point toward the room.
3. I will add new plastic vapor barrier between 2&4.
4. wall & stud
5. new insulation with barrier porint toward the room.
Old 01-04-2012, 10:21 AM   #4
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
With 2 layers of insulation, I'm not sure how the vapor barrier should be. Commonly, it would go on the other side of the studs than your drawing. This can depend on your location though. Where are you?
hyunelan2 is offline   Reply With Quote
Old 01-04-2012, 03:52 PM   #5
AGWhitehouse's Avatar
Remove that existing insulation. Place at least 1" of XPS (I recommend 2" for better vapor retarding capacity) against the foundation wall and then put up your stud wall. Only use un-faced batts within the stud bays and DO NOT put a vapor barrier on the inside face of the studs.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-05-2012, 09:30 AM   #6
Rewards Points: 131
i can understand the vapor barrier, but is it necessary to remove all existing insulation then put up new foam one against the concrete? would it be ok to romove or keep the existing insulation, then build wall 1" from foundation?
Old 01-05-2012, 09:46 AM   #7
I cannot recommend keeping fiberglass against concrete...
Old 01-05-2012, 11:54 AM   #8
Rewards Points: 131
is it because fiberglass doesn't keep moister from concrete to stud? but if i put a vapor barrier both side of the wall, wouldn't it solve the issues?
Old 01-05-2012, 01:16 PM   #9
Rewards Points: 2,212
It is impossible to 100% seal the fiberglass insulation with poly on both sides. Nails for trim, screws for drywall, the un-noticed little gap or tear. We used to use fiberglass in basements just like in the main floor of a house. It was wronge.
A good article http://www.buildingscience.com/docum...lation-systems
Look at this other recent thread on insulation and insulating basements. lots of good info.
EPS or XPS
mae-ling is offline   Reply With Quote
Old 01-05-2012, 01:57 PM   #10
Rewards Points: 672
I am in Minesota and doing exactly what AG recommends. I am using 1" board and will monitor the humidity level, making sure it is low enough in the summer. I saw on one of the Building Sciences links from this board that you should keep the humidy level below 50% if you use less than a 2" board.
B
Beepster is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Zone 6 - Wall Insulation: building out 2x4 walls DoItMyselfToo Building & Construction 15 05-06-2011 08:36 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
