New Wall Is Creaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2007, 01:27 PM   #1
JHill's Avatar
New wall is creaking
I just framed up a new wall in the 1st level on the house. The osb flooring has a little give it in and as you walk by, the top of the new wall creaks where it meets the ceiling.
I don't want to finish this off until I know a solution to this annoyance.
Thank you in advance for your ideas.
Jeff
JHill is offline   Reply With Quote
Old 07-17-2007, 06:07 PM   #2
Eibwen
If the framing is good it may just need a few shims to take the give out of it.
Sammy is offline   Reply With Quote
Old 07-17-2007, 11:26 PM   #3
Rewards Points: 5,336
How did you frame it? What size wood? What size/type of nail? What was the nailing pattern? How did you connect the new wall to the ceiling? Floor? Are there any gaps by the floor/ceiling?
Would help if you put some effort into the post so you could get worthwhile information back.
Ron
Old 07-18-2007, 09:07 AM   #4
JHill's Avatar
Sorry Ron,
I didn't know all that information was needed. I thought a squeaky wall was a squeaky wall. Never the less, a shim at the base and some 3 1/2" screws at the top have eliminated the problem.
Next time I post, I be sure to provide as many details as possible.
Thanks for your input.
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
