New Wall Construction, Sheathing Over Openings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 01:19 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
New wall construction, sheathing over openings
Is there any special consideration given to when plywood sheathing ends on windows?
I'm sheathing putting the sheets up horizontally and just covering the windows and just making sure that the end of the ply lands on a stud but if an end lands in the middle of a window, I just make sure that whereever the end of the sheet is, there is also a cripple. Then I'll cut out the windows. Is this correct or does it not matter?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-24-2008, 02:07 PM   #2
Registered User
Termite's Avatar
Nothing wrong with doing it that way. It makes for less measuring!
The APA's website has some excellent reading if you have questions regarding layout.
http://www.apawood.com/level_b.cfm?content=app_res_wind
Old 11-24-2008, 04:57 PM   #3
Plus you are sheltered from the elements when finishing any interior work (strapping or partitions). Where i'm from we get all the shelter we can. Some work lights on the inside and way to go!
DIYJIMBONL is offline   Reply With Quote
Old 11-24-2008, 05:54 PM   #4
thats the way we have always done it
kevin211mvd is offline   Reply With Quote
Old 11-24-2008, 06:41 PM   #5
knewbie
curapa's Avatar
I started doing it that way about 5 years ago and have never looked back. I use a router from the outside to make a perfect cut, I will also use my sawzaw from the inside if the window is to high off the ground.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 11-28-2008, 03:58 PM   #6
i have someone cut pieces to fit as i go you will find out it gets fairly easy and usually the rips are the same.
chad4290 is offline   Reply With Quote
Old 11-28-2008, 08:23 PM   #7
Framing Contractor
TIA
The sheet should land on a cripple stud no matter what you do because the cripple studs above the header and the jacks under the window sills should be following the rest of the studs 16" center layouts.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-29-2008, 12:51 PM   #8
knewbie
curapa's Avatar
I sheathed this way for years until I was told about the other method I mentioned. I have found that you can dramatically reduce your time by sheathing over windows and then cutting out. You then do not have to worry about any incorrect measurements and such. I put my helper on cutting the windows out while I move on to a more important task.
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
V shaped wall construction brosnt1 Building & Construction 3 02-08-2006 03:00 PM
