New Vinyl Windows, House Has Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 12:11 AM   #1
One-man DIY Army
New vinyl windows, house has siding
Ok, need a window contractor or expert advice here.
I'm replacing old windows with vinyl, but the old windows have a flange underneath the siding.
I've seen where people have just carefully run a circ saw (at a limited depth) around the perimeter of the window, discard the siding pieces, remove the window (because you now have unfettered access to the nailing flange), install the new window, and put in a 1x4 trim piece around the perimeter of the window, and seal the trim to the siding.
Any problem with doing this?
mdalli is offline   Reply With Quote
Old 09-19-2010, 06:08 AM   #2
Rewards Points: 111
What kind of siding?
luvdairish is offline   Reply With Quote
Old 09-19-2010, 07:20 AM   #3
Replacement wnidows, which fit into the old window frames, or new contruction windows, that requires the complete old frame be removed??? Nothing needed outside for replacement windows. Most new contruction windows have a nailing fin the requires siding removal, to install the window and to properly flash it. If you try to take shortcuts, you could end up with leaky windows.
The Following User Says Thank You to Just Bill For This Useful Post:
Tom Struble (09-19-2010)
Old 09-19-2010, 09:53 AM   #4
One-man DIY Army
It's almost certainly cedar siding.
So, the correct method is to pry all of the cedar planks off that touch the windows??
Sometimes, around here, the siding is a fiberboard that runs vertically. Prying it up to get at the nailing flange to replace the window would destroy it, which would mean re-siding large portions of the house.
Old 09-19-2010, 10:56 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
you could trim the siding away 3.5'' from around the windows then install the new units and retrim
Tom Struble is offline   Reply With Quote
Old 09-19-2010, 11:17 AM   #6
Rewards Points: 111
Sounds like a good idea to me
Old 09-19-2010, 11:19 AM   #7
i didn't see that
Old 09-19-2010, 12:48 PM   #8
kwikfishron's Avatar
Rewards Points: 998
I don’t know about the 1x4. I’d use 2x4 for trim so the trim is proud of the siding and window, so you have something to caulk to.
I’d only cut a couple of inches around the window to get the old out and the new in then hold the trim against the window, scribe and cut again.
kwikfishron is online now   Reply With Quote
New Vinyl Siding Went From $43k to $15k In A Few Days nycgto Off Topic 12 07-26-2010 11:46 PM
How to cut vinyl siding to vent bathroom fan? db_9 General DIY Discussions 9 11-13-2009 12:58 AM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
foam back siding vs. reg vinyl siding marnic Building & Construction 3 02-16-2009 07:48 AM
