New Tub Install - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 09:07 AM   #1
New Tub Install
I'm remodeling a bathroom & have removed the old fake marble tub & surround. I will be installing a Whirlpool tub & shower. The walls for the shower will be tile. I have a couple of questions.
1) For the walls behind the tile in the shower should I put sheetrock only, greenboard only, or durock only? Should it be a combination of sheetrock/greenboard and durock?
2) Should I put the tub in before the walls in question #1, or the walls first?
Thanks in advance for your help!,
Joe
JoeV is offline   Reply With Quote
Old 11-15-2008, 09:13 AM   #2
All trades carpenter
Joe
Hey Joe,
The tub usually goes from wall to wall so that needs to go in first so you can cut your tile to it. I prefer to use hardi backer for the walls. I then use "Red Gaurd" for the seams to keep water from penatrating the wall. I also put some mesh tape on the seams.
CrpntrFrk is offline   Reply With Quote
Old 11-15-2008, 11:20 AM   #3
Drywall contractor
Rewards Points: 1,070
Like Frk said, hardi or durock for tile backer. Tub first, regular rock (is ok) use green if you want, then tile backer. You want the double layer so you can use bullnose tile at the edges.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 11-17-2008, 09:29 AM   #4
Thanks for you're response. What is Red Guard and Mesh Tape & where do I get it?
Thanks again
Joe
Old 11-17-2008, 10:12 AM   #5
Drywall contractor
One other item.....when you hang the rock, keep it up off the tub lip 1/4" or 1/2" . If you set it down on the tub and any water gets in around the edge, it will "wick" up into the drywall and deteriorate it (regular or green).
Old 11-17-2008, 07:04 PM   #6
Thanks again
Joe
Red Guard is a waterproofing membrane. It also helps with seam control so your tile will not crack on a seam. Mesh tape it pretty much how it sounds. It has many uses. Most poeple know it for drywall applications. The Red Guard you might be able to find at Home Depot or a tile disributor. The mesh tape is so common it could even be found at Wal-Mart.
You'll want to put the mesh tape on all your seams including the corners. Then with a small nap roller apply the red guard to the area to be tiled. I usually do two coats.
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
Can I install 3/4" HW on top of the rolled floor membrane there now? davevarga Flooring 3 03-09-2008 10:16 PM
