New Trex Deck Just Installed With Wood Deck Screws Instead Of Composite- HELP PLEASE! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 05:45 PM   #1
New Trex Deck just installed with wood deck screws instead of composite- HELP PLEASE!
Our deck was just installed by a contractor who accidentally ordered non-composite deck screws. There is mushrooming occuring. Can he simply unscrew the wood deck screws and redo them with composite screws? If so, are there problems that may occur in the future?
JLayman is offline   Reply With Quote
Old 08-06-2009, 08:52 PM   #2
We pick these?
I think the only way you could tell would be to try one. If the heads on the composite decking screws are larger in diameter than the ones you have already maybe it will make the effect less mushroomy. Maybe you can turn the boards over and screw them through the same holes?
If none of that makes sense, I'd make the dude replace the boards that he messed up, if mess up he did. Or if you're not that cold, you could just wait for the mushrooming to wear down from normal use...
NailedIt is offline   Reply With Quote
Old 08-07-2009, 02:55 PM   #3
JLayman
I am a representative of Trex and would like to offer some input. You can remove the screws, though it will not be easy, and replace them with composite screws. We do make recommendation for screws we have tested that work well with Trex. Since mushrooming has aleady occurred, once the screws are removed, you may need to very gently tap the surface of the mushroomed area back down. If you want to speak to me directly, please contact me at 800-BUY-TREX.
Pat M
Trex Company
Pat M is offline   Reply With Quote
Old 08-07-2009, 10:20 PM   #4
We pick these?
I'm not a rep of a company, but I've worked with lots of Trex down in Port Aransas, Tx. I've gently used a 10lb sledge hammer (seriously, gently) to flatten the mushrooming effect. The stuff is pretty pliable.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
composite deck w39mcclurg General DIY Discussions 2 06-02-2009 02:36 PM
Composite deck building question Big Marino Carpentry 6 12-31-2008 10:14 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Trying to get screws to hold in soft wood fw2007 Carpentry 1 08-22-2007 09:20 PM
