-   -   New subfloor questions (http://www.diychatroom.com/f19/new-subfloor-questions-67609/)
simonb 03-25-2010 07:35 PM
Im about to dive into a second story bedroom project and have a few questions.
Older house, 24 on center real 2x6 joist. 2 layers of t&g giving it 1.5 inch thickness. Room is aprox 112" x 168".
Right now the floor is really bouncy and shakes the downstairs and with the moderate walking around in the room. First task i was going to do is remove flooring and sister the joists that are there now (glue and screw). Then i was going to run a heat duct through one of the paths and add blocking about every 4 feet where i can.
And now the questions;
1. What thickness should i go for the flooring? Should I just use jsut 1 layer or two? This room will have carpet.
2. Is it a bad idea to reuse the t&g? Its barely nailed down and im sure i can salvage most if not all of it.
thanks for any info...
Toolmaster 03-25-2010 07:44 PM
If you have the height, when you sister them up use 2x8's(2x10's would be awesome) some of the problem with bouncing might be that 2x6's really aren't used too much for a floor system spanning any more than 10 feet. Even that distance was a little bouncy. Using the 2x8's should firm it up a good bit and you only need one layer of 3/4" t&g, that second layer that was put on added more weight to the equation making it worse. I also don't know if you duct will fit in a 2x6 height.
simonb 03-25-2010 08:04 PM
Thanks for the quick reply Toolmaster.
I really cant use anything more then the 2x6 without making things complicated, i have some walls that are sitting on the joist and i dont have much height to play with.
I was going to get 2x8 and actually rip them to make them the same size as the old 2x6 for the sistering. As for the duct, i was going to run square ducting or 5 inch round, im almost sure it will fit as i have 24 on center and 6 inch height to play with.
Since 3/4 plywood is thick enough i still have to make up for the 3/4 missing, to make up for the difference maybe I can to use OSB to save money.
As for the blocking, the joist runs that dont have ducting i was going to block normaly, but the run with the duct i was going to turn the blocks so they lay flat above and/or bellow teh duct.
simonb 03-25-2010 08:17 PM
Well after re-reading the entire thread again, i think i might have answered my question. Let me know what you guys think.
my current joinst is 6" + 1-1/2" t&g double layer giving me 7-1/2 total.
I can get 2x8 (real size 1-1/2" x 7-1/4"), rip them to 6-3/4, use these to sister and raise the floor to height where all i need is 3/4 plywood.
At the location of the wall, closet of other room, there is just 1 joist that i would have to notch further down to 6" for 2 feet for it to sit on the first floor support wall.
Now this is all assuming that 3/4" is enough for 24 on center studs. Maybe 2 layers staggered of 1/2? or is this too thin and heavy? Any one else have an idea?
