New Stucco Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 01:15 AM   #1
New stucco question
I have this medium size area that I am stucco'ing and after the final layer I textured and misted it down, few hours later I noticed some small cracks in it already. What did I do wrong?
amdspitfire is offline   Reply With Quote
Old 06-16-2008, 10:55 AM   #2
Just had a little report on this very subject.I copied and pasted it for you to have a look at.Hope this helps you.
" A vertical and horizontal grid of cracks imply an improperly attached lath that increases internal stress. People will try to use a coating on top of it, but it's potentially one problem on top of another, there's not a good fix except for re-stuccoing.
Likewise, a spider webbing pattern of cracks indicates insufficient curing. The stucco is too thin or was installed at the wrong temperature.If water dries out too fast, you get an abnormal amount of shrinkage cracks.
Cracks near corners of a building often indicate that the lath was pulled too tight, causing a thinner application of stucco in that area. "If it's too thin, the water gets behind it and it just explodes.
Diagonal cracks often speak of deeper problems related to seismic activity, structural problems or both. A diagonal crack could represent a shifting foundation, settling or, if it occurs around windows or doors, improperly framed openings.
mark942 is offline   Reply With Quote
Old 06-16-2008, 01:15 PM   #3
I dont know if that helped the person who started this thread but it sure explained why part of my skin coat came apart thanks
clasact is offline   Reply With Quote
Old 06-16-2008, 05:18 PM   #4
I'm guessing it's due to the improperly attached lath, I had some play in the wire even though I had nailed it down plenty. The cracks are very thin, should I try to just cover them up?
Old 06-16-2008, 07:06 PM   #5
The choice is yours to make. If by chance you top-coat only to cover up the cracks, I would use a good Latex caulking.Elastomeric or a Mastic caulking would be a good choice as well.
clasact............I know what you mean.lol
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 03:26 PM
Stucco leak (long post) Pat B. General DIY Discussions 1 03-24-2006 07:54 PM
