New Slab Of Concrete Over Existing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 05:26 PM   #1
new slab of concrete over existing
Hi Everyone,
The screened patio that i currently have is a pain. The leveling is not perfect and the water drains to one spot and sits in the corner. What I would like to do is pour a new slab which is even with the framing of the screen and also has a pitch of a degree or two so the water drains away from the house and and right out of the screen area. Any ideas??? Thanks
jerasmo is offline   Reply With Quote
Old 02-23-2009, 06:55 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
you could pour a self leveling floor over your slab. there are companies that specialize in this. Its mainly used for radiant heated floors. but could be used for your task. I have used this process for basement floors with no problems. BOB
Old 02-24-2009, 12:19 PM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
If you're going to go through the trouble of pouring a new slab, you may as well just jackhammer out the one that is there and start new. The slab should drop an inch or so every foot (that's just a guess, do your research first) away from the house (everything should be graded away from the house, shouldn't it?).
I hate signatures.
Mort is offline   Reply With Quote
Old 02-24-2009, 12:58 PM   #4
ccarlisle's Avatar
"The slab should drop an inch or so every foot (that's just a guess, do your research first) away from the house..."
Huh?
I don't think so. Check it out.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 02-24-2009, 03:17 PM   #5
Crosby's Avatar
Hmmmmmm, Drop an inch per foot on a patio.
Crosby is offline   Reply With Quote
Old 02-24-2009, 05:01 PM   #6
SNC
How about 1/4 inch per foot
SNC is offline   Reply With Quote
Old 02-24-2009, 07:03 PM   #7
there is a method you can use to fill the bird bath - polymer-modified cement concrete works great - we do it all the time using a 6" sched 80 pipe for a screed - 1/4" per ft works !
yesitsconcrete is offline   Reply With Quote
Old 02-24-2009, 07:36 PM   #8
Mort's Avatar
Rewards Points: 692
See, I KNEW I wasn't correct. An inch every 4 feet. Now I remember.
That's why I just drive the truck. This stuff is done waaayyyy after I leave.
I thought that sounded kinda steep!
I hate signatures.
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
expanding existing concrete pad for shed lz300 Building & Construction 1 04-06-2008 08:20 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
