I'm getting ready to install new vinyl siding on my home. It currently has wood siding on it and I'd really like to remove it and start with a clean slate. The house was built in the 50's and stripping the outside will give me an opportunity to do blow-in insulation into the wall cavities which have little to no insulation currently. However, I'm running into an issue with the soffit. The previous homeowner had some nice aluminum soffit installed. When they did so, the installer attached the F-channel directly to the wood siding versus some sort of frame board. The issue that I'm concerned about it is when I pull the existing siding down I'm going to have a problem with the soffit. I'll either have to find a way to accurately cut a straight line in the upper-most siding board (the one that the f-channel is attached to) in order to leave it there and side up to the soffit, OR I'm going to have to take the soffit down and remove the siding and then reinstall the soffit and siding. If I do option #2, the soffit panels will be too short, right? One idea that I had to overcome that was to take out the soffit panels, remove all of the old siding, put up a new 1x4 board to attach the f-channel to, and then reinstall the soffit and siding. However, I'm not familiar enough with how to finish the top row of siding up against the soffit to know if that will work properly.
first thing i would check is to make sure there is adequate venting under the soffit,many times vented soffit is installed without cutting holes or removing the original wood soffit
you could carefully remove/replace the aluminum soffit but you may have to detail it differently as it may be too short after removing the underlying siding
That's why I was curious if I could carefully remove the soffit and then put up a 1x4 nailer board attached directly to the house in order to space it back out properly? That way I would hopefully not have an issue with the soffit panels being too short.
Thanks for the heads up on the venting. I'll make sure to check that out.
Possibly. I was actually planning on doing blow-in into the wall cavities from the outside. Then I'd do a Tyvek wrap. Wasn't sure if I'd need anymore than that or not?
You should be able to just go up the the attic and see if you have full venting in the soffit area.
One way to cut out that old frese board and not leave a space would be with a Toe Kick saw.
If you replaced it with 5/4 vinyl lumber it will cover the old F mold and be more then enough off set for the 1/2" J molding.
I install the J then insert a piece of utility trim (also called under sill) up side down in the J molding. When the siding is installed I punch it with a special rectanguler punch that leaves a tab. As the siding is inserted it snaps in place and is impossible to remove without a zipper tool and it can float free so it does not buckle. No face nailing, no silicone in the locking strip in the siding needed and will never come undone. http://www.house-energy.com/Cooling/Soffit.html
If you scroll down toward the bottom of this site it shows how to use just the under sill. Since you need to cover up the old F molding you need to add a piece of J first then the undersill to cover the gap.
Did some more thinking and research and after contemplating quite a bit, we went with no, I don't believe that we'll be replacing it. We'll probably be house shopping within a year or so and decided that with some decent prep and a fresh coat of paint, we'd be better off saving the money that we would have spent on installing new siding.
Now, another question on prepping for the new coat of paint. There are NUMEROUS coats of paint on the house. Some of it on the back (south) side of the home is chipping all the way down to the wood. It will obviously leave voids that, if painted over, will still be visible and look like crap. Is there some type of filler (think spackle or bondo) that you can purchase to put a little skim coat in those areas to help provide a flat surface to paint over? If so, details please.
i'll leave that to the painting pro's but it's nice to see you leaving the wood:thumbsup:
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
