New Siding Before New Roof? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 06:06 PM   #1
New siding before new roof?
I have an old farm house that will be getting new siding and a new roof this spring/summer. Its a 3 story house with two sides of the house having a porch roof that will be getting metal sheet roofing. I don't have the roof yet, but do have the hardieplank and I would like to put it up first. I would like to get the hardi up now because it will be easier to walk on the old shingle roof for installation and painting purposes. However I'm not sure how to go about flashing the roof after the siding is up as the panels have specific fitted wall flashing. I'm sure there's an easy way to do this I'm just not coming up with any ideas yet. Thanks.
Dan
Dbn107 is offline   Reply With Quote
Old 04-07-2010, 06:35 PM   #2
kwikfishron's Avatar
Rewards Points: 586
You can leave off the one coarse of siding above were the roof hits the house and finish that detail when you roof.
kwikfishron is online now   Reply With Quote
Old 04-07-2010, 07:21 PM   #3
yeah but then I'm not sure what to do about the corner boards.
Old 04-07-2010, 09:37 PM   #4
Rewards Points: 1,910
When the bottom edge of the wall ends on the roof doesn't the wall/roof flashing go over the shingles? So put the new flashing lapping the old shingles and apply your new siding. Then when you re-roof carefully pull the old shingles out from under the new flashing and slide the new shingles under.
Old 04-07-2010, 10:24 PM   #5
If I was putting shingles back up, yes that would work. I'm using a pocket rib metal panel that has a profile fitted flashing.
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
Siding where roof meets wall WSC Building & Construction 3 06-07-2009 12:18 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Roof and siding damage sando777 Roofing/Siding 6 07-29-2008 08:41 AM
