New Shed - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-04-2012, 10:16 PM   #16
beans50's Avatar
Originally Posted by woodworkbykirk
1/2" x 5" concrete wedge anchors - 25pc (anchoring bottom plates down to concrete floor
2x4x14' - 16 pc plate stock
2x4x 9' - 60 pc studs (allowing a few extra for possible windows openings)
2x12x8' - 3pc header for garage door
25 lb 3 1/2" hand spikes
25 lbs 2 1/4" ardox hand nails
20 sheets 7/16 wall osb
1 roll tyvek
1 box 3/8 staples (for hammer tacker or staple gun)
this is just the wall material as i dont know what you want for a roof design exactly. if you want a mansard roof your best bet is to order trusses built for the structure...
Thank you so much. This will really help a lot. Whenever i do it I'll make sure to put up pictures on this thread.
beans50 is offline   Reply With Quote
Old 03-04-2012, 10:25 PM   #17
Rewards Points: 13,694
Personaly I would not go with any prebuilt shed, reasons why.
There going to have stapled the shingles not nailed them.
Not enough over hang on the roof.
No drip cap on the sheathing.
Most do not even use tar paper on the roof.
Cheap high maintaince T-111 siding if it is vinyl siding it will be stapled on not nailed, not a good thing.
No Tyvek under the siding.
Old 03-04-2012, 10:27 PM   #18
Missouri Bound's Avatar
I'm sure you are correct. But the OP doesn't seem too sure what he wants and this is only a suggestion. And he probably couldn't build the prebuilt for less money.....just my opinion
Do you want it your way or the right way?
Old 03-04-2012, 11:20 PM   #19
beans50's Avatar
Originally Posted by Missouri Bound
Look around for a 20 X 12 kit. It will have everything you need to just stick a new shed on top of the existing foundation. You may even be able to buy a pre-assembled building they will deliver and drop right on your slab. But you will still have to get rid of the existing building.
Something like these...........
Derksen Portable Buildings
These are great, but i was looking for something i can build because I've always had an interest in building and construction and actually i want to either be an electrician or i wanna start with a construction company and work my way up to own my own company. So i don't want to buy some over-priced pre made building when i can build it myself, you know what I mean.
Old 03-05-2012, 08:02 AM   #20
It may be worth it to you to visit a library or look around online and find a good shed building book which covers design and fundamental building methods. Most of them will tell you how to figure openings, roofs, and structure in simple terms and just may save you money. Also "a picture is worth a thousand words" when it comes to describing how to do something. Anyway, best of luck with your project.
The Following User Says Thank You to Missouri Bound For This Useful Post:
woodworkbykirk (03-05-2012)
Old 03-05-2012, 06:11 PM   #21
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
good thought on looking for a book
the best books pertaining to anything carpentry are published by the taunton press, their the outfit that puts out fine homebuilding and fine woodworking magazines
woodworkbykirk is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
