Old 03-04-2012, 01:24 PM   #1
beans50's Avatar
New shed
Here is a picture of my shed now. I don't like it. But, what i came here for is to ask do you guys have any advice for me or any tips. I want to keep it basically the same and the dimensions will stay the same (20'x12') because there is a cement pad for the foundation. It's going to be made of wood and instead of the door on there i would like to install a pull up garage door. I was also wondering if you could give me a rough estimate of supplies and maybe a rough price. This would be very helpful. Thanks.
beans50 is offline   Reply With Quote
Old 03-04-2012, 01:30 PM   #2
Disabled wood vet
titanoman's Avatar
New shed
Are you going to doze it and start over?
Get rough estimates locally.
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
woodworkbykirk (03-04-2012)
Old 03-04-2012, 02:38 PM   #3
In a little over my head
New shed
Well, Beans, you said you wanted a project. Looks like you found one. Start with a book. I just used one on Framing, from Creative Homeowner. I liked it. Started at the bottom, worked up.
A REAL rough estimate:
1 2x4 stud per foot of perimeter
3 times the perimeter for the top and bottom plates, 2x4s
That amount of $ again for the roof framing.
Perimeter, in feet, divided by 4 for sheathing (4x8 sheets)
Sq footage x 1.5 for roof sheathing, felt and shingles.
Doors and windows as you like.
Do a little math, make a few calls. Hook up with a local lumber yard. They might help figure it out, and probably deliver.
ratherbefishing is offline   Reply With Quote
Old 03-04-2012, 03:07 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
New shed
draw up a sketch of exactly what you want, then post it. i can calculate the materials pretty quickly based on that if the drawing is detailed enough.. only thing you will need is to buy materials. anything extra i allow is for bracing.. to keep walls standing during the construction.. when its done that material can easily be turned into your new workbench.
normally i wont mention that ill calculate this sort of thing here but i see your young and keen. send me a pm and if i have time ill see what i can do.. currently working on 4 other estimates while having 4 renovations already on the go
woodworkbykirk is offline   Reply With Quote
Old 03-04-2012, 03:23 PM   #5
Love for Construction
<*(((><'s Avatar
New shed
Is the frame of the shed in bad shape? Everything appears to be pretty straight, especially the ridge. It might be beneficial for you to consider keeping the framing and stripping off the siding redoing it, reworking the gable end to accept a rollup door, and the money saved can be used to afford some niceties that wouldn't have been in the budget otherwise (i.e. electrical, interior walls, benches, tools, etc.)
I would have suggested otherwise, but since you are keeping the same dimensions and the condition of the shed from the picture SEEMS to be in good shape to put the money spent on what is already there (the framing) for other things.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-04-2012, 08:49 PM   #6
beans50's Avatar
New shed
I've thought about this an i would keep the frame but, 1) the bottom is all rotted out, and 2) i want it a little different. I want to make it a little higher (only about 2 feet) and add a loft for extra storage.
Old 03-04-2012, 09:14 PM   #7
beans50's Avatar
New shed
Thank you so much, this would help me a lot. This is my first real large scale project and i didn't want to go in alone. Here are pictures of a drawing i just did. Sorry for lack of artistic talent and good penmanship, but hopefully you can help me. And if not or your to busy or something don't worry about it. I could do this by myself maybe, but I'd rather make sure it was done right. Thanks again.
Old 03-04-2012, 09:23 PM   #8
New shed
For the maximum useable space you may want to go with this roof style.
http://www.barnplans.com/gambrelroof.php
Old 03-04-2012, 09:30 PM   #9
beans50's Avatar
New shed
I thought about that when i was first thinking about this whole project, but thanks and since someone else mentioned it i think I'll go with it. I'll have to take a trip to menards an see if they have any templates or something to help me with that.
Old 03-04-2012, 09:41 PM   #10
Missouri Bound's Avatar
New shed
If you are careful...and use adequate bracing you can replace one wall at a time (framing) without a problem. Any changes you need to make in the walls can be made as you build them. The roof doesn't look bad in the picture...do you need to replace the roof? It's only as complicated as you make it.
Do you want it your way or the right way?
Old 03-04-2012, 09:59 PM   #11
beans50's Avatar
New shed
Yes! The roof needs to be replaced. If i took a picture of the inside you would see that its surprising there is a roof. I'm exaggerating a little. But from a hail storm like 6 years ago the shingles are torn up on the side i didn't show in the picture. And actually just how the frame of the roof is, I would rather replace it to. And another thing is if i went with my dream shed thats in the drawings, it will actually be about 2 feet higher because i want a loft and actually cost wise and everything i might end up keeping it how it is and go with what you said and build 1 wall at a time. But the roof has to be replaced.
Old 03-04-2012, 10:06 PM   #12
New shed
Seem like you have to decide exactly what you want before any advice will make sense.
Old 03-04-2012, 10:09 PM   #13
New shed
1/2" x 5" concrete wedge anchors - 25pc (anchoring bottom plates down to concrete floor
2x4x14' - 16 pc plate stock
2x4x 9' - 60 pc studs (allowing a few extra for possible windows openings)
2x12x8' - 3pc header for garage door
25 lb 3 1/2" hand spikes
25 lbs 2 1/4" ardox hand nails
20 sheets 7/16 wall osb
1 roll tyvek
1 box 3/8 staples (for hammer tacker or staple gun)
this is just the wall material as i dont know what you want for a roof design exactly. if you want a mansard roof your best bet is to order trusses built for the structure...
Old 03-04-2012, 10:28 PM   #14
Disabled wood vet
titanoman's Avatar
New shed
Don't forget the treated plate.
Old 03-04-2012, 10:33 PM   #15
New shed
Look around for a 20 X 12 kit. It will have everything you need to just stick a new shed on top of the existing foundation. You may even be able to buy a pre-assembled building they will deliver and drop right on your slab. But you will still have to get rid of the existing building.
Something like these...........
Derksen Portable Buildings
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General Discussion 32 10-23-2012 09:54 PM
Zoning issue with planned shed Ler0y Jenkins General Discussion 15 02-01-2012 01:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
