New Roof For Paver Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 07:11 PM   #1
New roof for paver porch
Hello,
A few years ago I installed a new porch on the back of my house using pavers. The porch is about 30' wide and 14' deep, and is laid in the corner of the back of my house and an enclosed porch. I now want to install a roof over the paver porch.
I live in florida and have to be concerned with strong winds from hurricanes, but I do not want to make the roof too heavy.
Any suggestions on the materials I should use for joist's and roofing?
Thank you
choisnec is offline   Reply With Quote
Old 02-12-2012, 09:21 PM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Make sure the roof has good foundations (concrete filled Sonotubes) and proper embedded connectors to hold everything down and avoid uplift and damage to your home. Hurricanes are notorious for creating uplift damage from open sided roof systems and even when there is a garage door or gable end wall failure during a hurricane.
The roof can be light, but it should be held in place.
You may have some code/permit issues to address to protect your investment depending on your location in FL.
Dick
concretemasonry is online now   Reply With Quote
Vinyl siding above pitched porch roof - how to secure the bottom of the siding? joshoc Building & Construction 21 10-09-2010 12:42 PM
Need a good reference for tying in a Porch roof (gable) onto existing Hip roof bamawoody Building & Construction 5 04-17-2010 04:19 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Attaching Porch shed roof to Brick Veneer ApexTiger Building & Construction 46 02-16-2010 05:28 PM
32x10 Porch Addition with Gable Roof my5sons Building & Construction 4 11-17-2008 09:12 PM
