New Pole Building On Existing Asphalt Driveway That Sits On A Retaining Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2013, 02:57 PM   #1
new pole building on existing asphalt driveway that sits on a retaining wall
Hi everyone,
I recently purchased an old garage I want to convert into a pole building.I have an asphalt driveway with a large pad on it but the back side of it has a retaining wall that is about 6 feet tall. Question 1: how far away from the edge of the wall should I drill for posts to avoid the gravel backfill and drainage tile at the bottom, or do i not need to worry about hitting the edge of the gravel? Question 2: I also assume I need to go at least as deep as the wall is tall to hit virgin soil but I am not sure if that is deep enough or if I should go a little deeper to really plant it well.
All comments are appreciated,
joeyflaum is offline   Reply With Quote
Old 03-10-2013, 05:51 PM   #2
Rewards Points: 6,652
Those would be questions you would need to be asking your local ordinance office, since they are the ones that will have to issue the permit, to allow you to place the structure on your property.
power pole retaining wall ididit Landscaping & Lawn Care 17 07-05-2015 06:41 PM
How to repair a cracked driveway or walkway rfrick7@yahoo.c How To Guides 8 06-15-2015 04:59 AM
Short Retaining Wall - Footer jkim8520 Landscaping & Lawn Care 3 06-03-2011 11:27 AM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
building a pole barn on a existing slab??? scott13676 Building & Construction 3 02-25-2008 07:29 PM
