New Plumbing In Existing Concrete Slab/structural Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 06:46 PM   #1
new plumbing in existing concrete slab/structural question
I am putting a toilet on an exterior wall of a detached garage. The trick is not only cutting the slab, but I am imagining that right about where the toilet drain goes down and tees for fittings to stack in exterior wall etc is smack inside the perimeter footings for the slab. which I imagine to be about 12" wide and 18" deep. Any tips, tricks? thanks!
Justine is offline   Reply With Quote
Old 08-18-2011, 06:53 PM   #2
DIY staff
Rewards Points: 7,174
Do you hnow for sure that the detached garage has footings and a foundation wall---or is it a thickened slab.
Let us know what state or country you are in--that will help us determine the footing depth.
Old 08-20-2011, 12:51 PM   #3
Fairly positive there is a perimeter foundation fitting. It is in CA circa 1970, single story but probably designed for 2 storys.
Old 08-20-2011, 12:58 PM   #4
DIY staff
The only way to see what fits s to open the floor--if you have a sketch of the proposed room and where the drains will hook into the house plumbing--that will get you some good and useful suggestions.
---Mike---
Nice name---not very common---Mike--(One of my daughters has that name)
Old 08-20-2011, 01:06 PM   #5
Thanks Mike!
working on a drawing, but I don't know how to attach it.
Old 08-20-2011, 01:24 PM   #6
Not afraid of cutting concrete or anything, just not sure how to deal with this foundation. Are we even allowed to cut a slice out of it?
Old 08-20-2011, 01:52 PM   #7
DIY staff
You should not have a problem notching the foundation or footing for the new 3" drain.
We have a couple of engineers/ architects/designers here that will have a better idea .
Andy Gump is a California resident --hopefully he will spot this.---Mike---
I edited the title for more attention
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Connecting new plumbing into existing plumbing Just do it guy Plumbing 2 02-18-2008 10:36 PM
Concrete slab question houdinihar Building & Construction 2 06-07-2006 09:04 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-25-2005 12:40 AM
