New Opening In Masonry Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 12:52 PM   #1
New opening in masonry wall
I am thinking of installing a double French door in an existing CMU wall. The house is two stories with the first floor being all CMUs and the second wood framed. The wall that would get cut into would be the gable end of the house.
What I'm wondering is of there are any special requirement for the opening. For example, with a wood frame wall I'd need a header and jack studs to support the header. Is the same necessary for the masonry wall (ie solid block supporting a lentil)? So far both quotes I've received only mention installing a lentil and not grouting the blocks or adding soild blocks to the opening.
Thanks all!
Jeepsail is offline   Reply With Quote
Old 01-17-2010, 03:42 PM   #2
You should be fine with a new lintel as the block on either side will support it.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 01-17-2010, 03:50 PM   #3
I usually try to grout two cells down under the lintel
Wall Opening in CMU Frengineer Building & Construction 0 12-11-2009 03:27 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Extra large wall opening for outlet box fw2007 Electrical 4 10-03-2007 08:44 PM
MC or NM for exterior masonry wall? Redline77 Electrical 7 09-25-2007 03:05 PM
