-   -   new member with question on support beam (http://www.diychatroom.com/f19/new-member-question-support-beam-132328/)
pointer80 02-02-2012 02:02 PM
hi everyone, just found this site and it looks pretty awesome. espeacially since Ive been doing some remodeling. I have been wanting to put some added support beams in my basement. My home is 28' wide with a center beam so from the rim joist to the center beam is almost 14'. My floor joist are 2x8 set on 16" centers. I think that is a little on the lite side espeacially considering the remodeling I'm doing upstairs(my home is a single story ranch style) I would like to run a beam down the middle of each side at about the 7' mark just to help support the load and stiffen the floors. My question is would that be enough support and how far apart should I place my support post? Also what would be the best style beam and how wide and thick should it be to do the job? Thanks all and again awesome site.
psilva8 02-02-2012 02:09 PM
So you are thinking of reinforcing the joists? Have you considered any future renovations in the basement and how they may be effected by the new beam? Is it feasible to sister every other joists or something along those lines? Why kind of remodeling are you doing? Adding large jacuzzi tub?
pointer80 02-02-2012 02:13 PM
I do not plan on any remodeling in the basement and there is to much stuff in the way to sister the joist(wires, plumbing etc.) thank you.
psilva8 02-02-2012 02:45 PM
So what are you doing that requires the extra support?
mrgins 02-02-2012 02:56 PM
I'm guessing there's some bounce to the floor.
For resale value/buyer appeal (cos you WILL sell it at some point) you may want to avoid more beams and posts. You could stiffen the whole floor by screwing boards 12"-16"oc perpendicular to the joists. It won't add strength, but it will add stiffness which I think you're saying is the objective
pointer80 02-02-2012 06:27 PM
The reason I want to add beams is because I feel 2x8 joist are just too week espeacially to build on. I will probably not sell because I live on ten acres and have a heated shop and at 48 yrs. old I'm happy were I'm at. The one thing I would like to know is how many support post I would have to install. The length of the house is 52'. How far can I go between post and what size beam would provide adequate support. thank you.
framer52 02-02-2012 06:58 PM
You could use 2 2x8 for the beam or just mimic the current center beam
Spacing of posts also could mimic the center beams posts.
Remember you need to cut the concrete floor out and install a thicker concrete footers for the posts.
If it was me I wouldn't worry about it, unless you were going to be tiling a portion. The 2x8's floor joints are most likely sufficient.
WillK 02-02-2012 10:23 PM
Welcome, I'll just say briefly that circumstances can change and there will eventually be a point where the value of the house is important. This will diminsh the usable space in the basement, and could create an impression that the structure is suspect, both of which negatively will impact value and likelihood of success in selling the house.
There are difficult aspects to what you are considering if you mean to do it right. As already has been mentioned, your support posts will need to be supported by footings which will require you to break the concrete floor, dig out and pour, setting your attachments for your posts into the footing cement.
Even more difficult would be creating similar support for the ends of the beams. Your current center beam is probably supported by a beam pocket in the basement wall. That's a lot easier to create while you're building the basement wall. You could support the end with a post, but it won't be as clean.
The type of beam will have a bearing on how many supports are needed... If you have a steel I-beam chances are you would need more posts if you were considering a built up wood beam. Ultimately this should be specified by an engineer that reviews your project on site.
For what it's worth, I picked up a framing book in Home Depot and it has some basic span tables that helped me get some rough ideas what to expect ahead of contacting my engineer to specify the plans I used to permit and execute my project.
