New Kid Needs Beam Size Calculations! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 11:04 AM   #1
new kid needs beam size calculations!
Hi. I'm new here. I'm currently in an engineering class at my high school, but dont know how to determine the size of the beams that I need for my building. Can anybody offer any advice?
toadtheninja is offline   Reply With Quote
Old 05-24-2011, 11:15 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
Google.
12penny is offline   Reply With Quote
Old 05-24-2011, 12:59 PM   #3
tried that, didnt find anything
Old 05-24-2011, 12:59 PM   #4
dpach's Avatar
Your engineering teacher or books should have some instructions to use..... allowing for local building codes for both one and two story buildings. There should be some simple formulas to calculate based on load, support span, type of materials used, etc.
dpach is offline   Reply With Quote
Old 05-24-2011, 01:05 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
...I tried it too. Got 9.5million results.
Old 05-24-2011, 01:42 PM   #6
Rewards Points: 558
Youíre engineering class teacher should provide you with standard building code calculation specís for one and two story dwellings to size the beams needed. If they are over sized then he should show you how to calculate the load that is required.
epson is offline   Reply With Quote
Old 05-24-2011, 01:53 PM   #7
Rewards Points: 160
Maybe read your high school engineering class textbook?
cgoll is offline   Reply With Quote
Old 05-24-2011, 03:02 PM   #8
rock16's Avatar
Western Wood Products Assn has some handy tools that run on excel that can probably help you out.
rock16 is offline   Reply With Quote
What size beam to support loft with 16' between supports paperman Building & Construction 3 10-06-2009 05:40 PM
recessing a beam needa Building & Construction 12 12-26-2008 10:29 AM
Beam Size sevver Carpentry 15 04-30-2008 12:51 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
Beam Load Ron Building & Construction 5 09-17-2006 06:28 AM
