New Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-10-2010, 07:09 PM   #1
New Insulation
So I gutted a room. My house is made of concrete blocks. From the blocks there are thin boards which the sheet rock will be screwed on. There is only a gap of 1.5 - 2 inches. Which solution is best?
1.) Getting thin insulation to best fit the space
2.) Getting a thicker insulation and smush it in there.
3.) Use some type of spray foam.
mikegrous is offline   Reply With Quote
Old 09-10-2010, 07:33 PM   #2
Where are you located ?
Above ground ?
Thick insulation "smushed" in there you will end up w/reduced rvalue
...and fiberglass can't be up against concrete block usually
How far apart are the strips ?
I think I'd cut 2" thick rigid & install in between the strips
Then add 1/2" or 1" on top of everything & then drywall
Spray foam is also an option
Old 09-10-2010, 07:37 PM   #3
i am from connecticut. above ground. Strips are all diff distance apart.. 13.5 12.5 14.5 etc.
and there is only 1.5 - 2 inches inbetten where the drywall will be and where the concrete blocks are
Old 09-10-2010, 08:55 PM   #4
Sounds like a pretty stout house. I started to say I would go with Styrofoam but given the odd spacing of your batten boards spray in would probably be simplest.
I suppose it comes down to budget vs time.
Let us know how it come out.
Good Luck
Scottrik is offline   Reply With Quote
Old 09-11-2010, 08:27 AM   #5
Knucklez's Avatar
Rewards Points: 932
hey, you asked for the *best* solution.. that would be spray. it is waterproof, seals every nook & cranny and i think the R-value is better (could be wrong though). it will also save you time as this is not likely a DIY project (unless you know where to get spray foam from!??)
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-12-2010, 09:32 AM   #6
i was probably going to pay to have the spray insulation in and do the rest myself with my freind. thanks for the input
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
