Old 03-10-2007, 04:27 AM   #1
Question
New house purchase - work needed - how much will it cost?
Hi,
I'm the process of buying a 3 bed semi in Manchester and have had a survey done on it (though I've not received the full report as yet). However, I have been told some of the main work needed as follows:
* Front gully badly settled and also some adjacent bricks have slightly dropped - possibly broken drain and will need excavataion work and repair - could have also damaged house foundations in the area concerned - Any idea of how much this is likely to cost to repair?
* Some roof (tiled) needs patching - roughly how much? and how much for a NEW roof?
* Some repointing required - how much for repointing whole house?
* Damp treatment (partial required) but how much for FULL DPC?
* Wall ties required - how much?
I would be grateful for any input (as I need to decide on whether to go ahead with the purchase or not and how much (roughly I realise) it is likely to cost?
Thanks in advance, Ash
mchu6am4 is offline   Reply With Quote
Old 03-10-2007, 07:10 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by mchu6am4 View Post
Hi,
The first point you list would have most people running.
As far as the other points.....maybe someone could help you with these, however, the issues listed a too vague for me to give even a close estimate on. All the points are issues that need to be addressed on-site, thru visual inspections.
Example - New roof: No square footage listed, flashing?, current material match?, hips, gables, rotted plywood areas underneath?, etc..
Also, some repairs can't be simply 'price-listed' ......because there could be additional issues that need to be taken care of in order to perform the repair.
A home with the issues you listed sounds like one that has gotten ALOT of neglect. We have worked on neglect properties and have always found many, many more costly surpises were in store for the home owner....when the work started.
My 2 cents : Evidence listed shows an obvious neglected property = more costly issues will certainly come = Run like heck!....
- Build Well -
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 06:54 PM
opinions needed on waterproofing my house mike.frontier Building & Construction 7 02-18-2009 08:06 AM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
